BGP Path Selection
ilovebgp4
hi!Dear all
I have a BGP router learned a route through two way:one through eBGP,one through iBGP.For I preferred the iBGP path so I use route-map to set the eBGP route's origin to incomplete(the ORIGIN attribute has a higher priority in the decision process than IBGP/EBGP),but when I "show ip bgp",the router still preferred the incomplete route.What's reason?
Sugarbush#sh ip bgp 192.168.192.0 255.255.248.0
BGP routing table entry for 192.168.192.0/21, version 50
Paths: (2 available, best #1, table Default-IP-Routing-Table)
Advertised to non peer-group peers:
192.168.1.237 192.168.1.250
100, (aggregated by 100 172.16.0.21)
192.168.1.254 from 192.168.1.254 (172.16.0.21)
Origin incomplete, metric 0, localpref 100, valid, external, atomic-aggregate, best
100, (aggregated by 100 192.168.50.254)
192.168.1.245 (inaccessible) from 192.168.1.237 (192.168.255.253)
Origin IGP, metric 0, localpref 100, valid, internal, atomic-aggregate
Thanks a lot for your help!
Martin Parry
Level 3
Level 3
Ebgp has an administrative distance of 20 Ibgp has an admin distance of 200. The Ebgp path will be preferred.
ilovebgp4
Sorry,I found the problem.For not set the "next-hop-self" in the iBGP Peer,so the route learned from iBGP Peer's next hop is inaccessible.
Thanks for your help!
BTW:I found some configration code in "TCP/IP Volumn II"(by jeff dolyer) is not so integrated.
