BGP Peer-group Key chain authentication?
CiscoBrownBelt
Level 6
Level 6
I am trying to find documentation on how to configure BGP on routers to use a Key-chain but under Peer-groups. Any help guys/gals?
Jaderson Pessoa
you can use md5 password using for exemple:
neighbor AUTH peer-group
neighbor AUTH password (STRING)
look more information here: https://www.cisco.com/c/pt_br/support/docs/ip/border-gateway-protocol-bgp/112188-configure-md5-bgp-00.html
Jaderson Pessoa
*** Rate All Helpful Responses ***
Hello
Can you confirm what software you are using?
For IOS -As far as i am aware key chain for bgp isn't applicable on this software , only MD5 authentication is the allowed to authentic bgp neighbor peers groups/templates, However IOS-XE does allow key-chain on bgp for neighbor, peer groups/templates
Kind Regards
Paul
