router command
what is the command for Fa0/0.15 in s0/1/1 serial dce
5 Replies 5
Can I have the reply PLEASE
No.
I think it is unclear what you are asking. What are you trying to configure, a subinterface ? A serial interface functioning as the DCE ?
A subinterface would typically be configured like this:
interface FastEthernet0/0.15
encapsulation dot1q 15
ip address 192.168.15.1 255.255.255.0
The DCE needs clocking, so that would be:
interface Serial0/1/1
clock rate 64000
julian.bendix
Level 7
Level 7
I am not very sure what you mean exactly.
For a serial connection you need a DCE and a DTE side.
In Ethernet, there is no such thing, you don't need to set clocking on any side.
Does this answer your question?
Or was the question how to confige a FastEthernet Subinterface in general?
Best regards!
It was question about configure a interface
