bgp prefix-list question
whanson
Level 7
Level 7
Is there a difference between coding
0.0.0.0/0 and 0.0.0.0/32 if accepting
only the default route from the provider?
5 Replies 5
n.nandrekar
Level 9
Level 9
0.0.0.0/32 is not a valid address as the /32 mask would mean exact match of the ip address which is not valid.
Niranjan
hi dear friend,
In prefix-list /32 or /24 doesnt mean the wildcard bits dear.
It means the network prefix & hence /32 means any mask over here.
& 0/0 means only the default route.
You can check this on dynagen software.
atyalebipin
Community Member
Hi Friend,
Yes there is a difference in these two lists.
0.0.0.0/0 means only the default route is permitted or denied &
0.0.0.0/32 means any route is permitted or denied.
Bipin
Bipin,
Actually Niranjan is correct.
Prefix list for permit any would be 0.0.0.0/0 le 32 and not 0.0.0.0/32
Narayan
as always thanks.
