BGP prepend for certain network
Krasnoperov
Hi, I have an issue, I need to advertise for two ISP same network in bgp session. I have two routers with this config
ISP1(Router 1)
router bgp XXXXX
network 1.1.9.0 mask 255.255.252.0
network 1.1.11.0 mask 255.255.255.0
ISP2 (Router 2)
router bgp XXXXX
network 1.1.12.0 mask 255.255.255.0
I do this, because more specific route (/24) in bgp is prefered, and I receive incoming traffic through certain ISP.
Now I want to advertise ONLY this common (for both ISPs) network 1.1.9.0 mask 255.255.252.0 with different as-prepends, how can I do this through route-map?
JohnTylerPearce
Level 7
Level 7
I would think you would do the following.
ip access-list standard 1
permit 1.1.9.0 255.255.252.0
route-map prepend permit 10
match ip address 1
set as-path
router bgp
neighbor x.x.x.x route-map prepend out
I would think that should send out that specific network range to the specific ISP BGP neighbor, with multiple same
AS PATHs, so it should choose the other ISP over this one.
