BGP Prepend
tomek0001
Level 4
Level 4
Just a quick question, if i have a community string from an ISP that will prepend my route, if i set that community 3 times will it prepend it 3 times?
for example
xx:2200 prepend to peers (ISP XX )
if i set community on 1.1.1.0/24 xx:2200, xx:2200, xx:2200 would most ISPs prepend it 3 times?
Thank you,
Harold Ritter
Tomasz,
You can't set the same community more than once for given prefix. On the other hand, the ISP usually provides different communities to prepend the aspath a different number of time.
For instance:
xxx:2201 = prepend once, xxx:2202 = prepend twice and so on.
Harold Ritter
Tomasz,
For instance:
