BGP Prepend
JAMT
We have two router running iBGP and we have 3 ISPs all are in EBGP setup, 1 ISP connected to R1 and two ISPs connected to R2. x.x.67.0 network was originated in R1 and advertising thru BGP and we want when reaching this network it should use the primarily the WAN_LINK1 of R2. Therefore, i prepend the ISP peered to R1 and R2 WAN_LINK2 ISP, thus x.x.67.0 should learned primarily on WAN_LINK1 but when i checked x.x.67.0 network best path is learned from WAN_LINK2 ISP of R2.
Here are the configurations
R1
router bgp xx11
bgp router-id x.x.192.254
bgp log-neighbor-changes
network x.x.67.0
R2
interface GigabitEthernet0/0/3
description WAN_LINK1
ip flow monitor NTAMonitor input
ip flow monitor NTAMonitor output
ip address x.x.67.62 255.255.255.252
ip nat outside
ip access-group DENY_ACCESS in
speed 1000
no negotiation auto
interface GigabitEthernet0/0/4
description WAN_LINK2
ip address x.x.15.246 255.255.255.252
negotiation auto
router bgp xxxx
bgp router-id x.x.66.1
neighbor x.x.15.245 description WAN_LINK2
neighbor x.x.15.245 soft-reconfiguration inbound
neighbor x.x.15.245 route-map LINK2_IN in
neighbor x.x.15.245 route-map LINK2_OUT out
neighbor x.x.15.245 filter-list 1 out
neighbor x.x.67.61 remote-as xxxx
neighbor x.x.67.61 description WAN_LINK1
neighbor x.x.67.61 soft-reconfiguration inbound
neighbor x.x.67.61 route-map LINK1_OUT out
neighbor x.x.67.61 filter-list 1 out
ip prefix-list 67_Block seq 5 permit x.x.67.0/24 le 32
route-map LINK2_IN permit 10
set local-preference 200
route-map LINK1_OUT permit 10
match ip address prefix-list Block66 67_Block
route-map LINK1_OUT permit 20
match ip address prefix-list 64_Block 65_Block
set as-path prepend 7611 7611
route-map LINK2_OUT permit 10
route-map LINK2_OUT permit 20
match ip address prefix-list 65_Block 67_Block 66_Block
Can someone assist me what need to check or need to add on the configuration on our BGP.
Thanks a lot.
Hello
Looks like your route-map is incorrect, what you need to as-prepend matching on the prefix-list and then apply a catch al stanza at the end for any other traffic not maching the PF, Maybe adding an additional asn to one of the less preferred isp links in event of failover
Exampe:
set as-path prepend 7611 7611 7616
clear ip bgp * soft  <--perfrom a route-refresh soft reset
Kind Regards
Paul
Harold Ritter
Hi @JAMT ,
Where did you precisely check? On an Internet looking glass? Please provide more information on this.
Yes I used looking glass when i checked the bgp route.
