BGP Problem (Two ISPs)
CSCO12001340
Hello !
I am having trouble with my iBGP routes. I am really confused how to set it up properly. Can anyone tell me about the wrong configurations related to my topology ?  (ISP-1 CORE and ISP-2 CORE are Route Reflectors)
*** This topology should work without any interruption. For Example if Branch-x-isp-1 loses the iBGP neighborship with ISP-Core-RR , traffic should continue from the Banch-x-isp-2 router.
ISP-1 CORE RR CONFIG
router bgp 65000
bgp log-neighbor-changes
bgp redistribute-internal
neighbor 172.16.0.64 remote-as 65000
neighbor 172.16.0.64 route-reflector-client
neighbor 172.16.0.64 next-hop-self
neighbor 172.16.0.64 default-originate
neighbor 172.16.0.72 remote-as 65000
neighbor 172.16.0.72 route-reflector-client
neighbor 172.16.0.72 next-hop-self
neighbor 172.16.0.72 default-originate
neighbor 172.16.110.110 remote-as 65000
neighbor 172.16.110.110 route-reflector-client
neighbor 172.16.110.110 next-hop-self
ISP-2 CORE RR CONFIG
neighbor 172.16.110.101 remote-as 65000
neighbor 172.16.110.101 route-reflector-client
neighbor 172.16.110.101 next-hop-self
neighbor 172.29.51.209 remote-as 65000
neighbor 172.29.51.209 route-reflector-client
neighbor 172.29.51.209 next-hop-self
neighbor 172.29.51.209 default-originate
neighbor 172.29.60.27 remote-as 65000
neighbor 172.29.60.27 route-reflector-client
neighbor 172.29.60.27 next-hop-self
neighbor 172.29.60.27 default-originate
BRANCH-X-ISP-1
router bgp 65001
network 10.10.50.0 mask 255.255.255.0
neighbor 10.10.50.11 remote-as 65000
neighbor 10.10.50.11 route-reflector-client
neighbor 10.10.50.11 next-hop-self
neighbor 172.16.0.40 remote-as 65000
neighbor 172.16.0.40 next-hop-self
neighbor 172.16.0.40 route-reflector-client
neighbor 172.16.0.40 route-map LOCAL-PREF in (Sets LP to 600)
BRANCH-X-ISP-2
router bgp 65001
neighbor 10.10.50.10 remote-as 65000
neighbor 10.10.50.10 route-reflector-client
neighbor 10.10.50.10 next-hop-self
neighbor 172.27.107.220 remote-as 65000
neighbor 172.27.107.220 next-hop-self
neighbor 172.27.107.220 route-reflector-client
neighbor 172.27.107.220 route-map LOCAL-PREF in (Sets LP to 500)
BRANCH-Y-ISP-1
router bgp 65000
network 10.10.60.0 mask 255.255.255.0
neighbor 10.10.60.11 remote-as 65000
neighbor 10.10.60.11 route-reflector-client
neighbor 10.10.60.11 next-hop-self
BRANCH-Y-ISP-2
router bgp 65000
neighbor 10.10.60.10 remote-as 65000
neighbor 10.10.60.10 route-reflector-client
neighbor 10.10.60.10 next-hop-self
19 Replies 19
Julio E. Moisa
You should create a cluster list on the Core router to avoid any trouble. Now if everything is iBGP (they could be all over 65000, RR is used for iBGP only) and the branches are receiving the Internet or external routes from the Core routers you could remove the next-hop-self from them. Route-reflectors should be configured on the Core routers only.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi Julio, what is cluster list ? :/ Something like bgp peer group ?
The cluster id is a BGP command used to avoid loops using more than 1 route-reflector. Please check this link:
http://network-101.blogspot.com/2011/06/bgp-cluster-id-loop-prevention.html
Hi Julio,
Just to clarify, should i remove next-hop-self from the route reflectors or from the branch routers ?
chrihussey
On the surface it looks like there is way too much route reflecting going on. But you have some AS discrepancies and I think before any suggestion can be provided there needs to be some clarification. For example the ISP1-CORE-RR peering with BRANCH-X-ISP1 says it is AS65000, yet BRANCH-X-ISP1 is actually AS65001.
Can you identify which routers belong to which AS?
Hi Chris,
I corrected the AS numbers, it was a typing error just.
Sorry, but where are the corrections?
I edited my first post, all AS numbers will be 65000
To provide some additional information, the topology you have doesn't really allow for route reflectors the way you have things set up. Others may have different ideas but here are two suggestions:
1 - Have both cores peer with all the branch routers, create a cluster ID as Julio has suggested and define the branches as route reflector clients. Do not defined the cores as route reflector clients in the branch routers' peering to the cores. The branches only peer with the two cores. Then have the two cores peer with each other but not as route reflector clients.
2- Don't used route reflector clients at all and have all routers IBGP peer with each other. It is not a large topology and should work fine.
Finally, the assumption is that you are running an IGP (EIGRP, OSPF, ISIS, etc) supporting the BGP.
Hope this is of some help.
Hi Chris,
Thanks for your offers.
2- Don't used route reflector clients at all and have all routers IBGP peer with each other. It is not a large topology and should work fine. - I should use RR coz this is just a small part of the topology.
Hello
Do you have reachability to all of the rtrs within this ibgp domain, what routing protocol are you running for connectivity for each rtrs links?
FYI -
  • The RR's don’t need to be RR clients to each other and this also applies between the branch rts.
  • The branch rtrs don’t need ibgp peering to each other as that’s what the RR are for.
    Give both RR a cluster id so each rtr attaching to the their respective RR is known from cluster it is originating from
 router bgp 65000
cluster-id 10.10.10.10
no neighbor 172.16.110.110 route-reflector-client
 router bgp 65000
cluster-id 20.20.20.20
no neighbor 172.16.110.102 route-reflector-client
Branch xx
router bgp 65000
no neighbor 10.10.50.11
Branch xx
router bgp 65000
no neighbor 10.10.50.10
etc...
res
Paul
Kind Regards
Paul
Anyone has more comments about the topology ? :) Thanks to everybody.
Hello guys,
Thanks for your great replies. I fixed most of the topology by your comments.
1-I removed the iBGP peering between BRANCHX-ISP1 and BRANCHX-ISP2 (also for BRANCHYISP1-BRANCHY-ISP2)
2-I fixed the unnecessary next-hop-self commands
3-I removed the router-reflector-client commands between Core routers. (ISP1CORE and ISP2CORE)
But I just have one problem right now. I configured a same BGP CLUSTER ID value for both ISP1CORE and ISP2CORE. Now I can see just BRANCHX-ISP1 and BRANCHY-ISP1 advertised routes on ISP1CORE.
But what I need is , I want to see BRANCHX-ISP2 and BRANCHY-ISP2 routes on ISP1CORE as well. (For redundancy). To achieve this goal I want to establish a peering between
 BRANCHX-ISP2 <->ISP1CORE
 BRANCHY-ISP2 <->ISP1CORE
I am trying to configure ISP1CORE as a RR again for BRANCHX-ISP2 and BRANCHY-ISP2. But configuration fails. When i type show ip bgp summary, peering is not coming UP. It s stuck on IDLE.
How can I achieve this goal ?
Hello
@CSCO12001340 wrote:
Hello guys,
Try applying  ISP2 a different cluster ID
res
Paul
Kind Regards
Paul
