- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
08-11-2020 02:39 AM
hi i have Cisco 3650 POE+ sw. we have requirement to connect the external network over eBGP.
i want to know if eBGP is supported by cisco 3650 Sw ????
can some one help me.
Solved! Go to Solution.
- Labels:
Other Routing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-11-2020 03:34 AM
- Try this app :
M.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-11-2020 03:49 AM
this is from the datasheet attached:
--> The IP Services feature set is required for full OSPF, EIGRP, BGPv4, and IS-ISv4.
Scroll down to the section 'High Performance Routing':
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-11-2020 03:34 AM
- Try this app :
M.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-11-2020 03:49 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-11-2020 09:59 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-11-2020 06:52 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-11-2020 09:57 AM
i don't know my Cisco 3650 switch is IP service Feature set or not. is there any way to check it ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-11-2020 10:01 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-12-2020 02:01 AM
i have tried the commands but I got confuse again. in show version I can see L3 Software as you can see below logs but in show license its showing on LANBASE. so im not sure it is supporting BGP or not.
SW-1#sh ver
Cisco IOS Software [Denali], Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 16.3.6, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Wed 28-Feb-18 15:23 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2018 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 3.56, RELEASE SOFTWARE (P)
SW-1#sh license right-to-use
Slot# License Name Type Count Period left
1 lanbase permanent N/A Lifetime
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-12-2020 07:32 AM
Hello @Ravinder.pal ,
unfortunately LANBASE ha less features then IP Services so your switch C3650 at the moment does not support BGP at all.
As noted by Joseph even with the right license installed the device is not suitable to receive many routes like those in an Internet full table.
A device like this can be used in eBGP to exchange few prefixes with another enterprise.
The reason is in the TCAM size limitation that can host something like 8,000 routes or 16,000 routes just to make an example. (I didn't check but the values should be in this order of size)
Hope to help
Giuseppe
