BGP Question
Rick Morris
Level 6
Level 6
LAB Set-up
I have 2 CE routers running BGP with a PE router for site A
I have the mirror set-up for Site B
My issue is now running BGP between the two PE's and getting the routes to propagate between them.
How is this done?
CARRIER-A#sh ip bgp sum
BGP router identifier 210.1.1.1, local AS number 209
BGP table version is 2, main routing table version 2
2 network entries using 264 bytes of memory
3 path entries using 156 bytes of memory
3/1 BGP path/bestpath attribute entries using 444 bytes of memory
1 BGP AS-PATH entries using 24 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
Bitfield cache entries: current 1 (at peak 2) using 32 bytes of memory
BGP using 920 total bytes of memory
BGP activity 13/11 prefixes, 25/22 paths, scan interval 60 secs
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
123.2.2.2 4 209 77 76 2 0 0 01:10:39 1
208.10.10.1 4 1000 8780 8692 2 0 0 01:13:04 1
208.10.10.2 4 1000 1482 1465 2 0 0 01:13:02 1
CARRIER-A#sh ip bgp neigh 123.2.2.2 adv
BGP table version is 2, local router ID is 210.1.1.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*> 63.10.10.0/24 208.10.10.1 0 100 0 1000 i
Total number of prefixes 1
CARRIER-A#sh ip bgp neigh 123.2.2.2 ro
* i63.20.20.0/24 208.20.20.1 0 100 0 1000 i
CARRIER-A#ping 63.20.20.1
Sending 5, 100-byte ICMP Echos to 63.20.20.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
CARRIER-A#sh ip route 63.20.20.1
% Subnet not in table
CARRIER-A#sh ip bgp 63.20.20.1
BGP routing table entry for 63.20.20.0/24, version 0
Paths: (1 available, no best path)
Not advertised to any peer
1000
208.20.20.1 (inaccessible) from 123.2.2.2 (210.2.2.1)
Origin IGP, metric 0, localpref 100, valid, internal
router bgp 209
no synchronization
bgp log-neighbor-changes
neighbor 123.2.2.2 remote-as 209
neighbor 123.2.2.2 ebgp-multihop 2
neighbor 123.2.2.2 update-source Loopback10
neighbor 123.2.2.2 version 4
neighbor 208.10.10.1 remote-as 1000
neighbor 208.10.10.1 ebgp-multihop 2
neighbor 208.10.10.1 update-source Loopback0
neighbor 208.10.10.1 version 4
neighbor 208.10.10.1 default-originate
neighbor 208.10.10.1 route-map MONROE-IN in
neighbor 208.10.10.1 route-map MONROE-OUT out
neighbor 208.10.10.2 remote-as 1000
neighbor 208.10.10.2 ebgp-multihop 2
neighbor 208.10.10.2 update-source Loopback0
neighbor 208.10.10.2 version 4
neighbor 208.10.10.2 default-originate
neighbor 208.10.10.2 route-map MONROE-IN in
neighbor 208.10.10.2 route-map MONROE-OUT out
no auto-summary
24 Replies 24
Rick
Sorry for delay in replying but looks like Giuseppe has been helping out.
See you've made a few changes regarding AS numbers. Is this all you changed in configs ie. can i still use the configs you posted before.
Can you also post "sh ip route" from Carrier A, "sh ip route" from carrier B and "sh ip bgp"/"sh ip route" from CE-A in site B.
Promise i'll stay with it this time :-)
Jon
no worries Jon...I understand how things go throughout the day.
I have enjoyed this a lot and have seen you and Guiseppe comment on previous posts as well as others and knew I would get great guidance.
I am hoping to be on more and assist as you have done, even with my limited knowledge, it is stretching me.
Rick
Just had a look at configs. On carrier A & carrier B under bgp config can you change -
router bgp 209
synchronisation
to
router bgp 209
no synchronisation
Jon
Hello Rick,
Jon's right you need to disable synchronization too or each device waits for the IGP to have the route before passing the eBGP advertisement to the iBGP peer.
Hope to help
Giuseppe
This just keeps getting more weird.
I have made the change to no sync, but had done that before and it did not work, now it appears to be working.
So from the carrier to carrier I am able to ping:
BGP routing table entry for 63.20.20.0/24, version 3
Paths: (1 available, best #1, table Default-IP-Routing-Table)
Multipath: eBGP
64513
123.2.2.2 from 123.2.2.2 (210.2.2.1)
Origin IGP, metric 0, localpref 100, valid, internal, best
Routing entry for 63.20.20.0/24
Known via "bgp 209", distance 200, metric 0
Tag 64513, type internal
Last update from 123.2.2.2 00:44:00 ago
Routing Descriptor Blocks:
* 123.2.2.2, from 123.2.2.2, 00:44:00 ago
Route metric is 0, traffic share count is 1
AS Hops 1
Route tag 64513
Multipath: eBGP
64513
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/3/4 ms
CARRIER-B#sh ip bgp 63.10.10.1
BGP routing table entry for 63.10.10.0/24, version 3
64512
123.1.1.2 from 123.1.1.2 (210.1.1.1)
CARRIER-B#sh ip route 63.10.10.1
Routing entry for 63.10.10.0/24
Tag 64512, type internal
Last update from 123.1.1.2 00:44:56 ago
* 123.1.1.2, from 123.1.1.2, 00:44:56 ago
AS Hops 1
Route tag 64512
CARRIER-B#ping 63.10.10.1
Sending 5, 100-byte ICMP Echos to 63.10.10.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/4/4 ms
This is working, thank you!!!
Now I tried this one step in and it did not work......
HPTR001-A#ping 63.10.10.1
HPTR001-A#sh ip bgp 63.10.10.1
BGP routing table entry for 0.0.0.0/0, version 7
209
123.2.2.1 from 123.2.2.1 (210.2.2.1)
Origin IGP, metric 0, localpref 100, valid, external, best
I am getting default routes from the PE router (Carrier B) I should just send my traffic to Carrier B and Carrier B does have it in its table it should get there, but it does not.
Sorry I feel like a big pain in the butt on this.
Hello Rick,
Before you had the same AS number on CE nodes so you couldn't see the effect of no sync command.
Hope to help
Giuseppe
ahh...you are correct!
Oh I wish I could blink my eyes and make it all work.
Now to figure out why I cannot ping end to end.
Rick
What device is HPTR001 ?
If you try a traceroute from that device how far do you get ?
Jon
in the topology it looks like this
hptr001a -- carrierB -- carrierA -- monr001a
I also have redundant connections at each customer edge
so in my rack it looks like this
monr001A
monr001B
carrierA
carrierB
hptr001A
hptr001B
monr001A | | hptr001A
|----carrierA----carrierB----|
monr001B | | hptr001B
HPTR001-A#traceroute 63.10.10.1
Tracing the route to 63.10.10.1
1 157.130.0.9 [AS 209] 0 msec 0 msec 0 msec
2 * * *
3 * * *
the 157.130.0.9 is the serial IP of the carrier router.
CARRIER-B#sh ip int b
FastEthernet0/0 172.16.0.2 YES manual up up
Service-Engine0/0 unassigned YES NVRAM administratively down down
FastEthernet0/1 unassigned YES NVRAM administratively down down
Serial0/0/0 157.130.0.9 YES manual up up
Serial0/1/0 157.130.0.13 YES manual up up
Serial0/3/0 unassigned YES unset administratively down down
Loopback0 123.2.2.1 YES manual up up
Loopback10 123.2.2.2 YES manual up up
Loopback100 210.2.2.1 YES manual up up
Found it.
My carrier routers did not know the routes between the CE connected routes.
I added redistribute connected so now all those routes are in the routing table and it worked.
