BGP question
cy_yeh
I have a BGP topology as below. (please see attachment more detail)
<1> R1 is BGP AS65011 and R2 is BGP AS65012
<2> There are two links between R1 and R2 , one is MPLS ,another is FTTB.
        Both links establish BGP.
<3> These two links are not load-balance.
       I prefer some subnets through MPLS and some subnets through FTTB.
Question: Is there any concern or problem about this topology and configuration ?
Thanks.
Best Regards,
Luke Yeh
Amit Goyal
If you have some applications running which are sensitive to asymmetric routing, you could face some issues with this application.
If you are preferring some subnets via MPLS but return is preferring via FTTB, will cause an asymmetric routing.
-Amit
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
BGP, by default, doesn't ECMP.  However, Cisco routers can usually be configured to do so.
If you want some subnets to use one path, you may need to use something like PBR.
If you want dynamically load balance, you may want to consider OER/PfR.
