BGP redistribute route not showing in EIGRP
G3000LEE
This is a quick lab I just drafted up.
The issue not seeing Loobback 0 BGP route that should have been redistributed into EIGRP on R1 or R2.
This topology should cause a loop in the network when trying to reach 10.1.1.4 on R4 but that's not what I want to be pointed out.
Any help with why I am not seeing the BGP routes on R2 and R1 would be appreciated.
R3#show run | sec router
router eigrp 1
network 192.168.23.3 0.0.0.0
redistribute bgp 64512 metric 100 1 255 1 1500
router ospf 1
router bgp 64512
bgp log-neighbor-changes
network 192.168.34.0
redistribute connected
redistribute eigrp 1
neighbor 192.168.34.4 remote-as 64512
R3#show ip route
10.0.0.0/24 is subnetted, 1 subnets
B 10.1.1.0 [200/0] via 192.168.34.4, 00:27:17
D 192.168.12.0/24 [90/3072] via 192.168.23.2, 00:27:17, GigabitEthernet0/1
192.168.13.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.13.0/24 is directly connected, GigabitEthernet0/0
L 192.168.13.3/32 is directly connected, GigabitEthernet0/0
192.168.23.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.23.0/24 is directly connected, GigabitEthernet0/1
L 192.168.23.3/32 is directly connected, GigabitEthernet0/1
192.168.34.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.34.0/24 is directly connected, GigabitEthernet0/2
L 192.168.34.3/32 is directly connected, GigabitEthernet0/2
R4#show run | sec router
router bgp 64512
network 10.1.1.0 mask 255.255.255.0
neighbor 192.168.34.3 remote-as 64512
R4#show ip route
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 10.1.1.0/24 is directly connected, Loopback0
L 10.1.1.4/32 is directly connected, Loopback0
B 192.168.12.0/24 [200/3072] via 192.168.23.2, 00:11:35
B 192.168.13.0/24 [200/0] via 192.168.34.3, 00:11:38
B 192.168.23.0/24 [200/0] via 192.168.34.3, 00:11:38
C 192.168.34.0/24 is directly connected, GigabitEthernet0/0
L 192.168.34.4/32 is directly connected, GigabitEthernet0/0
R1#show run | sec router
router eigrp 1
network 192.168.12.1 0.0.0.0
redistribute ospf 1 metric 100 1 255 1 1500
router ospf 1
redistribute eigrp 1 subnets
R1#show ip route
192.168.12.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.12.0/24 is directly connected, GigabitEthernet0/0
L 192.168.12.1/32 is directly connected, GigabitEthernet0/0
C 192.168.13.0/24 is directly connected, GigabitEthernet0/1
L 192.168.13.1/32 is directly connected, GigabitEthernet0/1
D 192.168.23.0/24 [90/3072] via 192.168.12.2, 01:32:49, GigabitEthernet0/0
D EX 192.168.34.0/24
[170/25600768] via 192.168.12.2, 00:03:43, GigabitEthernet0/0
R2#show ip route
L 192.168.12.2/32 is directly connected, GigabitEthernet0/0
D EX 192.168.13.0/24
[170/25600512] via 192.168.12.1, 00:18:32, GigabitEthernet0/0
L 192.168.23.2/32 is directly connected, GigabitEthernet0/1
[170/25600512] via 192.168.23.3, 00:03:22, GigabitEthernet0/1
2 Accepted Solutions
Bgp-Redistrubte -internal
Ususally ibgp not redistrubte into igp until you enter command above
Hello
As stated you will need to tell the bgp router to allow bgp to be redistribute into eigrp
Rtr3
router bgp xx
bgp redistribute-internal
Kind Regards
Paul
Hello
Rtr3
router bgp xx
Kind Regards
Paul
