View External IP Address Dual Wan RV340w
AlexCPCisco
We have a RV340w with dual wan.  Is there a way to view the external IP address of each WAN.
These are not static and can change.  I need to check them and update the white list on some of our external servers.
I can see the IP adress that has been assigend from the Wan (eg 10.x.x.x) but I cannot seem to see the external IP addresses of each WAN
 If they have access to the internet properly and you wanto to discover which IP address they are using, you just need to access some web site like https://whatismyipaddress.com/
 Do it from one machine connected to the lan, of course.
