05-23-2022 04:08 PM
See attached diagram for details.
I want R2 to advertise only “10.100.254.1/32” to R3 using a route-map.
How do I do this?
R1/R2 are running OSPF
R2/R3 are running eBGP
44/r2 are running eBGP
=== R2 Config ===
interface Loopback0
ip address 10.100.1.1 255.255.255.255
router ospf 100
log-adjacency-changes
redistribute bgp 2 subnets
network 10.0.0.0 0.255.255.255 area 0
router bgp 2
no synchronization
bgp log-neighbor-changes
network 10.100.1.1 mask 255.255.255.255
network 68.0.0.0 mask 255.255.255.0
network 70.0.0.0 mask 255.255.255.0
aggregate-address 10.100.0.0 255.255.0.0 summary-only
neighbor 68.0.0.3 remote-as 3
neighbor 68.0.0.3 soft-reconfiguration inbound
neighbor 70.0.0.4 remote-as 4
neighbor 70.0.0.4 soft-reconfiguration inbound
no auto-summary
R2#sh ip bgp neighbors 68.0.0.3 advertised-routes
BGP table version is 12, local router ID is 10.100.1.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*> 3.3.3.3/32 68.0.0.3 0 0 3 i
*> 10.0.0.0 70.0.0.4 0 0 4 i
*> 10.100.0.0/16 0.0.0.0 32768 i
*> 68.0.0.0/24 0.0.0.0 0 32768 i
*> 70.0.0.0/24 0.0.0.0 0 32768 i
*> 172.16.0.0 70.0.0.4 0 0 4 i
*> 192.168.0.0/16 70.0.0.4 0 0 4 i
Total number of prefixes 7
R2#sh ip bgp
s> 10.100.1.1/32 0.0.0.0 0 32768 i
* 70.0.0.4 0 0 4 i
=== R1 Config ===
interface Loopback0
ip address 10.100.254.1 255.255.255.255
router ospf 100
R1#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
68.0.0.0/24 is subnetted, 1 subnets
O E2 68.0.0.0 [110/1] via 10.100.100.2, 02:14:18, FastEthernet0/0
70.0.0.0/24 is subnetted, 1 subnets
O E2 70.0.0.0 [110/1] via 10.100.100.2, 02:14:18, FastEthernet0/0
3.0.0.0/32 is subnetted, 1 subnets
O E2 3.3.3.3 [110/1] via 10.100.100.2, 00:01:48, FastEthernet0/0
O E2 172.16.0.0/16 [110/1] via 10.100.100.2, 00:01:48, FastEthernet0/0
10.0.0.0/8 is variably subnetted, 5 subnets, 4 masks
O E2 10.0.0.0/8 [110/1] via 10.100.100.2, 00:01:49, FastEthernet0/0
C 10.100.254.1/32 is directly connected, Loopback0
O 10.100.1.1/32 [110/11] via 10.100.100.2, 03:34:20, FastEthernet0/0
O E2 10.100.0.0/16 [110/1] via 10.100.100.2, 00:01:44, FastEthernet0/0
C 10.100.100.0/24 is directly connected, FastEthernet0/0
O E2 192.168.0.0/16 [110/1] via 10.100.100.2, 00:01:50, FastEthernet0/0
=== R4 Config ====
R4#sh run | sec router bgp
router bgp 4
no synchronization
network 10.10.10.4 mask 255.255.255.255
network 172.16.100.4 mask 255.255.255.255
network 192.168.0.0 mask 255.255.0.0
network 192.168.100.4 mask 255.255.255.255
aggregate-address 10.0.0.0 255.0.0.0 summary-only
aggregate-address 172.16.0.0 255.255.0.0 summary-only
aggregate-address 192.168.0.0 255.255.0.0 summary-only
neighbor 70.0.0.2 remote-as 2
no auto-summary
05-23-2022 04:40 PM - edited 05-23-2022 05:23 PM
router bgp 2
no synchronization
network 68.0.0.0 mask 255.255.255.0<- this wrong *
network 70.0.0.0 mask 255.255.255.0<- this wrong *
no auto-summary
wrong since these NET is connect two BGP peer then network will unstable because it learn net connect two BGP through BGP, remove this
for commend you need for advertise
route-map OUT permit 10
match ip add 10
ip access-list 10
permit ip host 10.100.254.1
router bgp 2
neighbor R3 route-map OUT out
05-23-2022 06:45 PM
It did not work - See config and output below:
==== BEFORE I HAD THE CONFIG ===
==== AFTER I ADD THE CONFIG =====
Total number of prefixes 0
==== CONFIG ADDED ====
R2#sh run | sec router bgp
router bgp 2
no synchronization
redistribute ospf 100
neighbor 68.0.0.3 route-map OUT out
no auto-summary
access-list 10 permit 10.100.254.1
match ip address 10
05-23-2022 07:21 PM
10.100.254.1/32 or 10.100.1.1/32??
I dont see 10.100.254.1/32 connect or learn in R2 so how R2 advertise non connect non learn via other routing protocol prefix to R3.
If you want add static route to null0 then use under bgp network command and finally use same command it previously mention.
05-24-2022 05:18 AM
10.100.254.1/32 is learned from R1 via OSPF.
05-24-2022 08:28 AM
OK learn from OSPF then you need under BGP R2
redistribute ospf x subnet
this make R2 redistribute the prefix from OSPF into BGP
then the route-map will filter prefix and only 10.100.254.1/32 will advertise.
05-23-2022 07:48 PM
Hi @MEDIAOS ,
You need to add an extra network statement for 10.100.254.1/32 under BGP in R2, but you also need to remove the aggregate-address statement if you want the more specific routes to be advertised to R3.
router bgp 2
network 10.100.254.1 mask 255.255.255.255
no aggregate-address 10.100.0.0 255.255.0.0 summary-only
05-24-2022 03:30 PM
Hello
R2
Remove all aggregates AND soft-reconfiguration inbound from the bgp stanza and then you could add the following
route-map LOOPBACK
match interface loopback 0
router bgp 2
redistributed connected route-map LOOPBACK
05-25-2022 01:09 AM
Hello
R2
route-map LOOPBACK
router bgp 2
06-07-2022 04:26 PM
On R2
router bgp 65511 bgp log-neighbor-changes no bgp default ipv4-unicast neighbor 68.0.0.2 remote-as 65509 neighbor 70.0.0.2 remote-as 65510 ! address-family ipv4 redistribute ospf 1 neighbor 68.0.0.2 activate neighbor 68.0.0.2 route-map ToR3 out neighbor 70.0.0.2 activate exit-address-family ! ip prefix-list FILTERTOR3 seq 5 permit 10.100.254.1/32 ip prefix-list FILTERTOR3 seq 10 deny 0.0.0.0/0 le 32 ipv6 ioam timestamp ! route-map ToR3 permit 10 match ip address prefix-list FILTERTOR3
On R3
06-07-2022 05:02 PM
Redistrubte opsf do the job,
Great man.
06-07-2022 09:02 PM - edited 06-07-2022 09:03 PM
Hello
I see the host prefix originates from R1 so my original suggestion would not work- but i see you have advertised it with a prefix-list and route-map- so all good!
06-15-2022 12:33 PM
Did you test my proposed solution?
