BGP route distribution
DMALTENFORT
I am having problems getting a loopback address to publish through BGP and am hoping someone can lend a hand.      This is running on an 1841 router.  I have four subinterfaces off of the F0/0 interface, a loopback and serial interface:
sh ip int br
FastEthernet0/0.10         10.10.98.1      YES NVRAM  up                    up
FastEthernet0/0.13         unassigned      YES unset  administratively down down
FastEthernet0/0.15         10.15.98.1      YES NVRAM  up                    up
FastEthernet0/0.150        10.150.1.5      YES manual up                    up
FastEthernet0/0.156        10.151.1.5      YES NVRAM  up                    up
FastEthernet0/1            unassigned      YES NVRAM  administratively down down
Serial0/0/0                unassigned      YES NVRAM  up                    up
Serial0/0/0.1              199.2.2.2 YES NVRAM  up                    up
Loopback0                  10.30.98.1      YES manual up                    up
I want to publish the following subnets:
10.10.98.0/24
10.15.98.0/24
10.30.98.1/32
I do not want to publish the following:
10.150.0.0 /16
10.151.0.0 /16
router bgp 60098
synchronization
bgp log-neighbor-changes
network 10.10.98.0 mask 255.255.255.0
network 10.15.98.0 mask 255.255.255.0
network 10.30.98.1 mask 255.255.255.255
redistribute connected
neighbor 199.2.2.1 remote-as 65111
distribute-list acl-filter out
no auto-summary
ip access-list standard acl-filter
permit 10.30.98.1 log
permit 10.10.98.0 0.0.0.255
permit 10.15.98.0 0.0.0.255
deny   10.150.0.0 0.0.255.255
deny   10.151.0.0 0.0.255.255
I am getting the 10.10.98.0, 10.15.98.0 and am not getting 10.150.0.0 and 10.151.0.0.  The problem is that I am also not getting 10.30.98.1
Thanks in advance for any assistance.
Giuseppe Larosa
Hello David,
I would check with
show ip bgp 10.30.98.1
if the BGP advertisement is in the BGP table.
  With no auto-summary configured the network command requires an exact match to work.
May you post also sh run int loop0 and/or show ip interface loop0?
Hope to help
Giuseppe
Thanks Guiseppe:
The problem was that the IP address was set to:
10.30.98.1/24 instead of 10.30.98.1/32.
Thanks again,
David
