BGP route learning but not able to ping
Sureshbabu
Pease find the below lab configuration.
R1 and R2 same AS . R3 and R4 is different AS.
i have advertise the two network
(6.6.6.6/32 & 7.7.7.7/32)
Both the network im able to ping R2 and R3. But not able to ping R4.
R4 both neighbor establish state and routes are lean in BGP.
R4#sh ip bgp 6.6.6.6
BGP routing table entry for 6.6.6.6/32, version 2
Paths: (2 available, best #2, table Default-IP-Routing-Table)
Flag: 0x820
Advertised to update-groups:
10.10.10.13 from 10.10.10.13 (3.3.3.3)
Origin IGP, localpref 100, valid, external
10.10.10.9 from 10.10.10.9 (2.2.2.2)
Origin IGP, localpref 100, valid, external, best
R4#sh ip bgp 7.7.7.7
BGP routing table entry for 7.7.7.7/32, version 3
Flag: 0x820
R4#ping 6.6.6.6
Sending 5, 100-byte ICMP Echos to 6.6.6.6, timeout is 2 seconds:
Success rate is 0 percent (0/5)
R4#
R4#ping 6.6.6.6
Success rate is 0 percent (0/4)
R4#ping 7.7.7.7
Sending 5, 100-byte ICMP Echos to 7.7.7.7, timeout is 2 seconds:
R1
int fa0/1
ip add 10.10.10.1 255.255.255.252
no shut
int fa0/0
ip add 10.10.10.5 255.255.255.252
no shut
int loo1
ip add 1.1.1.1 255.255.255.255
router bgp 10
bgp router-id 1.1.1.1
no synchronization
no auto-summary
neighbor 10.10.10.6 remote-as 30
neighbor 10.10.10.2 remote-as 10
R2
int fa0/1
ip add 10.10.10.2 255.255.255.252
no shut
int fa0/0
ip add 10.10.10.9 255.255.255.252
no shut
int loo1
ip add 2.2.2.2 255.255.255.255
router bgp 10
bgp router-id 2.2.2.2
no synchronization
no auto-summary
neighbor 10.10.10.10 remote-as 40
neighbor 10.10.10.1 remote-as 10
R3
int fa0/1
ip add 10.10.10.13 255.255.255.252
no shut
int fa0/0
ip add 10.10.10.6 255.255.255.252
no shut
int loo1
ip add 3.3.3.3 255.255.255.255
router bgp 30
bgp router-id 3.3.3.3
no synchronization
no auto-summary
neighbor 10.10.10.14 remote-as 40
neighbor 10.10.10.5 remote-as 10
R4
int fa0/1
ip add 10.10.10.14 255.255.255.252
no shut
int fa0/0
ip add 10.10.10.10 255.255.255.252
no shut
int loo1
ip add 4.4.4.4 255.255.255.255
router bgp 40
bgp router-id 4.4.4.4
no synchronization
no auto-summary
neighbor 10.10.10.13 remote-as 30
neighbor 10.10.10.9 remote-as 10
Pleas suggest
2 Accepted Solutions
You need to know there is different between traffic pass through router and traffic initiate from router'
When we do ping without source we initiate traffic from router' the destiantion is add but what about source? If we dont use source with ping the router will select one interface IP' here this step make ping drop becuase the destiantion router not known this source of ping to reply. So when we initiate traffic from router always we need source (this source is know by destiantion router).
For you case you
ping 6.6.6.6
from R4 but what is source of this ping ? It can unknown by R1' when we make R4 advertise
lo 4.4.4.4
and use it as source of ping solve this issue.
Hi @Sureshbabu
Use
 Redistribute connect sunet
if you dont want to ender the command network repeatly times.
 One router needs to tell the others routers  the network it holds on its network advertisements.
 Either you use the network stetament if you want to be specific or redistribute if you want to all at once.
10 Replies 10
You use bgp neighbor only
There is no
redistrubte connect
Nor netword <LO> mask
So bgp is run but not advertise anything
Sureshbabu
Updated R1 configuration
R1#sh run | sec bgp
router bgp 10
no synchronization
bgp log-neighbor-changes
network 6.6.6.6 mask 255.255.255.255
network 7.7.7.7 mask 255.255.255.255
no auto-summary
Loopback1 1.1.1.1 YES manual up up
Loopback2 6.6.6.6 YES manual up up
Loopback3 7.7.7.7 YES manual up up
Sorry dont get what you do?
R1 have only lo 1.1.1.1 not 6.6.6.6 nor 7.7.7.7
Config each router to advertise it connect LO
Note:- after each router advertise it LO use ping as following
For R1
Ping 6.6.6.6 source 1.1.1.1
Source of ping is important here to test bgp
Sureshbabu
6.6.6.6 and 7.7.7.7
both network locally originated in R1.
i have advertised in BGP using network command.
in R4 both network are learning but not able to ping.
i want to know why its not able to  ping
Ok'
Then
In R4 advertise it LO 4.4.4.4 via bgp
From R4 do
Ping 6.6.6.6 source 4.4.4.4
Sureshbabu
Thank now able to ping.
Can you please more information previous why its not ping.
For you case you
ping 6.6.6.6
lo 4.4.4.4
Note:- dont use
redistrubte
connected without filtering' I will share lab why it recommends not to
redistrubte
connect in bgp without filtering.
Hi @Sureshbabu
Use
