BGP route-map in use
Amafsha1
Level 2
Level 2
Hello I'm trying to figure out if this route-map is in use.
I go to the core of my network and I see the following:
Core1#
router eigrp 1
redistribute static route-map static-to-eigrp
redistribute bgp 65425 route-map static-to-eigrp
default-information originate
 sh route-map static-to-eigrp
route-map static-to-eigrp, permit, sequence 100
Match clauses:
Set clauses:
metric 100 1 255 1 1500
Yet the core of my network does not have any BGP process...There is no BGP running.  Is the command above useless?
Harold Ritter
If you do not run BGP, you certainly do not need to redistribute bgp in eigrp. I imagine that BGP might have been configured in the past and it was removed, but the redistribute statement was not.
Harold Ritter
awesome thank you.  Just making sure that's true.
