BGP Route-Map-PBR
Joe Lee
Hello All-
We have MPLS network via the BGP routing protocol. As you see the diagram, Site A and Site B have two links.
1. In Site A, the Link 1 is only allow 10.10.10.0/24 coming in, and 10.10.100.0/24 going out; In Site B, the Link 1 is only allow 10.10.100.0/24 coming in, and 10.10.10.0/24 going out.
2. Both Link2 to for all the traffic, expcet 10.10.10.0/24 and 10.10.100.0/24.
3. Also, we need to have reduandancy, if Link 1 fails, all the traffic should go to Link 2; If Link 2 fails, all the traffic should go to Link 1.
Any thought?
Joe
Sindhu_kumar
  Hi Lee,
          By Using Route-map we can achieve this I think. I tested this it working fine as you like
SITE_A#
SITE_A#sh ip access-lists SUB_10
Standard IP access list SUB_10
    10 permit 10.10.10.0, wildcard bits 0.0.0.255 (26 matches)
SITE_A#
SITE_A#sh route-map LINK1_IN
route-map LINK1_IN, permit, sequence 10
  Match clauses:
    ip address (access-lists): SUB_10
  Set clauses:
    weight 500
  Policy routing matches: 0 packets, 0 bytes
route-map LINK1_IN, permit, sequence 20
  Match clauses:
  Set clauses:
    weight 600
SITE_A#
SITE_A#sh route-map LINK2_IN
route-map LINK2_IN, permit, sequence 10
  Match clauses:
  Set clauses:
    weight 400
route-map LINK2_IN, permit, sequence 20
  Match clauses:
  Set clauses:
    weight 700
SITE_A#
SITE_B#
SITE_B#sh ip access-lists SUB_100
Standard IP access list SUB_100
    10 permit 10.10.100.0, wildcard bits 0.0.0.255 (33 matches)
    20 deny   any log (30 matches)
SITE_B#
SITE_B#sh route-map LINK1_IN
  Match clauses:
    ip address (access-lists): SUB_100
  Set clauses:
    weight 500
  Match clauses:
  Set clauses:
    weight 600
SITE_B#
SITE_B#sh route-map LINK2_IN
  Match clauses:
  Set clauses:
    weight 400
  Match clauses:
  Set clauses:
    weight 700
SITE_B#
Failover Testing by shutting down the primary link
PC_100_SUB#
PC_100_SUB#sh ip int brief | i up
FastEthernet0/1            10.10.100.2     YES manual up                    up
PC_100_SUB#
PC_100_SUB#ping 10.10.10.2 re 2
Sending 2, 100-byte ICMP Echos to 10.10.10.2, timeout is 2 seconds:
Success rate is 100 percent (2/2), round-trip min/avg/max = 80/110/140 ms
PC_100_SUB#
PC_100_SUB#tra 10.10.10.2
Tracing the route to 10.10.10.2
  1 10.10.100.1 28 msec 16 msec 20 msec
2 10.240.186.77 12 msec 44 msec 4 msec
  3 192.168.10.2 80 msec 20 msec 64 msec
  4 10.240.186.54 136 msec 8 msec 120 msec
  5 10.10.10.2 120 msec *  60 msec
PC_100_SUB#
SITE_A#sh int Serial0/0 | i line|/30|Des
Serial0/0 is up, line protocol is up
  Description: << VSNL-1st-Link >>
  Internet address is 10.240.186.78/30
SITE_A#
SITE_A#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
SITE_A(config)#int Serial0/0
SITE_A(config-if)#shut
SITE_A(config-if)#
*Mar  1 06:19:49.846: %BGP-5-ADJCHANGE: neighbor 10.240.186.77 Down Interface flap
SITE_A(config-if)#^Z
SITE_A#
SITE_A#
*Mar  1 06:19:51.598: %SYS-5-CONFIG_I: Configured from console by console
*Mar  1 06:19:51.822: %LINK-5-CHANGED: Interface Serial0/0, changed state to administratively down
SITE_A#
SITE_A#
SITE_A#sh ip bgp
BGP table version is 17, local router ID is 10.240.186.78
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 10.10.10.0/24    10.240.186.9                         400 65500 64667 i
*> 10.10.20.0/24    10.240.186.9                         700 65500 64667 i
*> 10.10.100.0/24   0.0.0.0                  0         32768 i
*> 10.10.200.0/24   0.0.0.0                  0         32768 i
SITE_A#
PC_100_SUB#
Success rate is 100 percent (2/2), round-trip min/avg/max = 128/144/160 ms
PC_100_SUB#
  1 10.10.100.1 64 msec 24 msec 36 msec
  2 10.240.186.9 44 msec 20 msec 20 msec
  3 192.168.20.2 76 msec 56 msec 24 msec
  4 10.240.186.54 92 msec 48 msec 28 msec
  5 10.10.10.2 104 msec *  88 msec
PC_100_SUB#
Serial0/0 is administratively down, line protocol is down
SITE_A#conf t
SITE_A(config-if)#no shut
SITE_A#
SITE_A#sh ip bgp
BGP table version is 18, local router ID is 10.240.186.78
*> 10.10.10.0/24    10.240.186.77                        500 65500 64667 i
*                           10.240.186.9                         400 65500 64667 i
*  10.10.20.0/24     10.240.186.77                        600 65500 64667 i
*>                         10.240.186.9                         700 65500 64667 i
SITE_A#
Failover Testing by shutting down the secondary link
PC_10_SUB#
PC_10_SUB#sh ip int brief | i 10.10
FastEthernet0/1            10.10.10.2      YES manual up                    up
PC_10_SUB#
PC_10_SUB#traceroute 10.10.200.1
Tracing the route to 10.10.200.1
  1 10.10.10.1 56 msec 24 msec 16 msec
  2 10.240.186.57 56 msec 36 msec 28 msec
  3 192.168.10.1 44 msec 48 msec 68 msec
  4 10.240.186.78 128 msec *  88 msec
PC_10_SUB#
SITE_B#sh ip bgp
BGP table version is 5, local router ID is 10.10.20.1
*> 10.10.10.0/24    0.0.0.0                  0         32768 i
*> 10.10.20.0/24    0.0.0.0                  0         32768 i
*  10.10.100.0/24    10.240.186.57                        400 65500 64613 i
*>                         10.240.186.53                        500 65500 64613 i
*> 10.10.200.0/24   10.240.186.57                        700 65500 64613 i
*                           10.240.186.53                        600 65500 64613 i
SITE_B#
SITE_B#sh int Se0/0 | i line|/30|Des
  Description: << VSNL 2nd Link >>
  Internet address is 10.240.186.58/30
SITE_B#
SITE_B#conf t
SITE_B(config)#int Se0/0
SITE_B(config-if)#shu
SITE_B(config-if)#
*Mar  1 06:34:53.414: %BGP-5-ADJCHANGE: neighbor 10.240.186.57 Down Interface flap
SITE_B#
SITE_B#sh ip bgp
BGP table version is 6, local router ID is 10.10.20.1
*> 10.10.100.0/24   10.240.186.53                        500 65500 64613 i
*> 10.10.200.0/24   10.240.186.53                        600 65500 64613 i
SITE_B#
PC_10_SUB#
  1 10.10.10.1 92 msec 44 msec 56 msec
2 10.240.186.53 40 msec 76 msec 96 msec
  3 192.168.10.1 80 msec 76 msec 72 msec
  4 10.240.186.78 92 msec *  108 msec
PC_10_SUB#
Hi Sindhu,
Sorry for late reply...business trip for two months. Can you please provide me the configuration for both sites?
Joe
