BGP & route-maps
mohAmed khAdr
Pls. can you guys take a look at this lab and tell me what am missing?
I can't ping accorss from R3_AS_100 to R1_AS_200 & from R4_AS_100 to R2_AS_300
Thx.
mohamed
Reza Sharifi
Mohamed,
from R3_AS_100 to R1_AS_200 Can you ping the physical addresses? if yes, can you ping the loopback addresses?
Is BGP peering established?
Reza
Reza,
No< I can't ping either....
peering is establised so is the routes
I thing I misconfig the route-maps.
Pls. take a look @ these sh outputs.
Thx.
mohamed
Your route-maps are denying everything because there is the default implicit deny all at the end so you have to add on both R2 and R1:
route-map KHADR 20
Then do a route refresh: clear ip bgp * in on both routers and you should be good to go.
Regards.
Alain.
