What is Kbps in QOS?
simon.males.bi
I have a SRP521W (Firmware: 1.01.19 (004) Jan 7 2011) and the Upstream Bandwidth field is specified in Kbps.
Assuming:
kbps = Kilobit per second
kBps = Kilobyte per second
What is Kbps ?
Hi Simon,
The terminology what they used in the Screenshot is the right one. Kilobits per second can be shortened to kb/s or  Kbps or kbps .
Do rate helpful posts.
With Regards,
Aravind K.J
johnlloyd_13
Level 9
Level 9
hi,
if talking about bandwidth or throughput, it would be kilobits per second. kilobytes are used to refer device's memory or some sort of hardware capacity.
Aravind K.J
Hi Simon,
A bit is a single numeric value, either '1' or '0', that encodes a single unit of digital information. A byte is a sequence of 8 bits.
Usually, data communication speed is measured in bits/kilobits/megabits per second, while storage space is measured in bytes/kilobytes/megabytes.
In data communications, a Kilobit is one thousand bits. It is used to measure the amount of data transferred per second. Kilobits per second is shortened to kb/s, Kbps or kbps (as opposed to KBps, which is Kilobytes per second. Note the capitalization). The lowercase b is commonly used to denote bits, while the uppercase B is used for bytes.
1 kb/s = 1000 bits per second
1 KB/s = 1024 bytes per second
P.S :  Please mark this thread as answered if you feel your query is resolved.  Do rate helpful posts.
With Regards,
Aravind K.J
Thanksk for you help. Though I would like to point out that the current firmware uses incorrect terminology.
Surely this should be logged as a bug?
Hi Simon,
With Regards,
Aravind K.J
