887 command change
James Simpson
Hi All
I have recently up swapped out an 877 router for an 887 router and have copied the config template accross
however it will not take 3 of my commands.
AAA accounting system default stop-mly group tacas+
ip inspect name firewall cuseeme timeout 3600
dsl operating -mode auto
Please could you help
Rohit Nair
You could be using an IOS on the 887 that does not support those particular features.
You could go to Cisco Feature Navigator and compare the features of both the IOS's that you've got on the 887 and the 877.
Thank you
