BGP route question
Psycho_naT
Exampe:
show ip bgp vpnv4 vrf "vrf-name" sum | i 1234
10.244.11.14     4   1234  6934899   6290661    164944     0         0     41w1d                     0
10.244.12.14     4   1234  7080720   6290660    164944     0         0     41w1d                     0
10.244.13.14     4   1234  7731806   6290758    164944     0         0     41w1d                   43
10.244.14.14     4   1234  7195156   6290775    164944     0         0     41w1d                   33
10.244.15.14     4   1234  6993135   6290663    164944     0      0      1w2d                       0
10.244.16.14     4   1234  7008760   6290663    164944     0         0      1w2d                       0
10.244.17.14     4   1234  7122383   6290672    164944     0         0      1w2d                 2792
show ip bgp vpnv4 vrf "vrf-name" 192.168.2.100 255.255.255.255
BGP routing table entry for 65000:500:192.168.2.100/32, version 164944
Paths: (8 available, best #1, table "vrf-name")
Not advertised to any peer
1234 65000
10.244.17.14 from 10.244.17.14 (10.254.254.121)
Origin incomplete, localpref 100, valid, external, best
Extended Community: RT:65000:500
1234 65000, (received-only)
1234 65000 65000 65000, (received-only)
10.244.16.14 from 10.244.16.14 (10.254.254.121)
10.244.15.14 from 10.244.15.14 (10.254.254.121)
10.244.14.14 from 10.244.14.14 (10.254.254.121)
10.244.11.14 from 10.244.11.14 (10.254.254.121)
10.244.13.14 from 10.244.13.14 (10.254.254.121)
10.244.12.14 from 10.244.12.14 (10.254.254.121)
Question: why i get two entries about 192.168.2.100/32 subnetwork from the same neighbor 10.244.17.14 ?
"vrf-name" - it's local routing table using for local purposes only, no iBGP neighbors.
Raju Sekharan
You are seeing this becasue of soft-reconfig
(received-only) is  raw data from peer before applying any policy
The other entry ( best path) shows how this raw data was modified by the policy applied on the router
Raju
Thanks !
You are welocme
Raju
