BGP Routes not showing
mimarop@
What could be the problem when BGP route 172.16.0.0/24 from vIOS9 is not showing multiple paths to vIOS6, vIOS4, vIOS8, while both paths to 172.16.0.0/24 is showing in vIOS2 and vIOS3. Below are the config as well.
vIOS6#sh run | sec bgp
router bgp 200
bgp router-id 6.6.6.6
bgp log-neighbor-changes
network 1.1.1.0 mask 255.255.255.252
network 3.3.3.0 mask 255.255.255.252
network 20.20.20.0 mask 255.255.255.252
network 172.17.0.0 mask 255.255.255.0
neighbor 1.1.1.1 remote-as 100
neighbor 3.3.3.2 remote-as 300
neighbor 20.20.20.2 remote-as 200
neighbor 20.20.20.2 next-hop-self
vIOS9#sh run | sec bgp
router bgp 100
bgp router-id 2.2.2.2
network 2.2.2.0 mask 255.255.255.252
network 172.16.0.0 mask 255.255.255.0
neighbor 1.1.1.2 remote-as 200
neighbor 2.2.2.2 remote-as 400
vIOS1#sh run | sec bgp
router bgp 400
bgp router-id 8.8.8.8
network 40.40.40.0 mask 255.255.255.252
network 50.50.50.0 mask 255.255.255.252
neighbor 2.2.2.1 remote-as 100
neighbor 40.40.40.1 remote-as 400
neighbor 40.40.40.1 next-hop-self
neighbor 50.50.50.2 remote-as 400
neighbor 50.50.50.2 next-hop-self
vIOS4#sh run | sec bgp
router bgp 400
bgp router-id 7.7.7.7
network 4.4.4.0 mask 255.255.255.252
network 5.5.5.0 mask 255.255.255.252
network 60.60.60.0 mask 255.255.255.252
network 70.70.70.0 mask 255.255.255.252
network 192.168.30.0
neighbor 60.60.60.1 remote-as 400
neighbor 60.60.60.1 next-hop-self
neighbor 70.70.70.1 remote-as 400
neighbor 70.70.70.1 next-hop-self
neighbor 192.168.10.1 remote-as 300
neighbor 192.168.10.1 ebgp-multihop 2
neighbor 192.168.10.1 update-source Loopback20
vIOS8#sh run | sec bgp
router bgp 300
bgp router-id 11.11.11.11
network 30.30.30.0 mask 255.255.255.252
network 172.18.0.0 mask 255.255.255.0
network 192.168.10.0
neighbor 3.3.3.1 remote-as 200
neighbor 30.30.30.2 remote-as 300
neighbor 30.30.30.2 next-hop-self
neighbor 192.168.30.1 remote-as 400
neighbor 192.168.30.1 ebgp-multihop 2
neighbor 192.168.30.1 update-source Loopback20
vIOS6#sh ip bgp
BGP table version is 24, local router ID is 6.6.6.6
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
x best-external, a additional-path, c RIB-compressed,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
Network Next Hop Metric LocPrf Weight Path
* 1.1.1.0/30 1.1.1.1 0 0 100 i
*> 0.0.0.0 0 32768 i
*> 2.2.2.0/30 1.1.1.1 0 0 100 i
* 3.3.3.0/30 3.3.3.2 0 0 300 i
*> 4.4.4.0/30 3.3.3.2 0 0 300 i
*> 5.5.5.0/30 3.3.3.2 0 0 300 i
* i 20.20.20.0/30 20.20.20.2 0 100 0 i
*> 30.30.30.0/30 3.3.3.2 0 0 300 i
* 40.40.40.0/30 1.1.1.1 0 100 400 i
*> 3.3.3.2 0 300 400 i
* 50.50.50.0/30 1.1.1.1 0 100 400 i
* 60.60.60.0/30 1.1.1.1 0 100 400 i
* 70.70.70.0/30 1.1.1.1 0 100 400 i
*> 172.16.0.0/24 1.1.1.1 0 0 100 i
*> 172.17.0.0/24 0.0.0.0 0 32768 i
*> 172.18.0.0/24 3.3.3.2 0 0 300 i
* 172.19.0.0/24 1.1.1.1 0 100 400 i
*> 192.168.10.0 3.3.3.2 0 0 300 i
*> 192.168.30.0 3.3.3.2 0 300 400 i
vIOS4#sh ip bgp
BGP table version is 24, local router ID is 7.7.7.7
*> 1.1.1.0/30 192.168.10.1 0 300 200 i
*> 2.2.2.0/30 192.168.10.1 0 300 200 100 i
*> 3.3.3.0/30 192.168.10.1 0 0 300 i
* 4.4.4.0/30 192.168.10.1 0 0 300 i
* 5.5.5.0/30 192.168.10.1 0 0 300 i
*> 20.20.20.0/30 192.168.10.1 0 300 200 i
*> 30.30.30.0/30 192.168.10.1 0 0 300 i
*>i 40.40.40.0/30 60.60.60.1 0 100 0 i
*>i 50.50.50.0/30 70.70.70.1 0 100 0 i
* i 60.60.60.0/30 60.60.60.1 0 100 0 i
* i 70.70.70.0/30 70.70.70.1 0 100 0 i
*> 172.16.0.0/24 192.168.10.1 0 300 200 100 i
*> 172.17.0.0/24 192.168.10.1 0 300 200 i
*> 172.18.0.0/24 192.168.10.1 0 0 300 i
*>i 172.19.0.0/24 60.60.60.1 0 100 0 i
*> 192.168.10.0 192.168.10.1 0 0 300 i
*> 192.168.30.0 0.0.0.0 0 32768 i
vIOS8#sh ip bgp
BGP table version is 24, local router ID is 11.11.11.11
*> 1.1.1.0/30 3.3.3.1 0 0 200 i
*> 2.2.2.0/30 3.3.3.1 0 200 100 i
* 3.3.3.0/30 3.3.3.1 0 0 200 i
* 4.4.4.0/30 192.168.30.1 0 0 400 i
* 5.5.5.0/30 192.168.30.1 0 0 400 i
*> 20.20.20.0/30 3.3.3.1 0 0 200 i
* i 30.30.30.0/30 30.30.30.2 0 100 0 i
*> 40.40.40.0/30 192.168.30.1 0 400 i
*> 50.50.50.0/30 192.168.30.1 0 400 i
*> 60.60.60.0/30 192.168.30.1 0 0 400 i
*> 70.70.70.0/30 192.168.30.1 0 0 400 i
*> 172.16.0.0/24 3.3.3.1 0 200 100 i
*> 172.17.0.0/24 3.3.3.1 0 0 200 i
*> 172.18.0.0/24 0.0.0.0 0 32768 i
*> 172.19.0.0/24 192.168.30.1 0 400 i
*> 192.168.10.0 0.0.0.0 0 32768 i
*> 192.168.30.0 192.168.30.1 0 0 400 i
vIOS2#sh ip bgp
BGP table version is 21, local router ID is 9.9.9.9
* i 1.1.1.0/30 60.60.60.2 0 100 0 300 200 i
*>i 40.40.40.2 0 100 0 100 i
* i 2.2.2.0/30 60.60.60.2 0 100 0 300 200 100 i
*>i 40.40.40.2 0 100 0 i
* i 3.3.3.0/30 40.40.40.2 0 100 0 100 200 i
*>i 60.60.60.2 0 100 0 300 i
* i 4.4.4.0/30 40.40.40.2 0 100 0 100 200 300 i
*>i 60.60.60.2 0 100 0 i
* i 5.5.5.0/30 40.40.40.2 0 100 0 100 200 300 i
* i 20.20.20.0/30 40.40.40.2 0 100 0 100 200 i
*>i 60.60.60.2 0 100 0 300 200 i
* i 30.30.30.0/30 40.40.40.2 0 100 0 100 200 300 i
* i 40.40.40.0/30 40.40.40.2 0 100 0 i
*>i 50.50.50.0/30 40.40.40.2 0 100 0 i
* i 60.60.60.0/30 60.60.60.2 0 100 0 i
*>i 70.70.70.0/30 60.60.60.2 0 100 0 i
* i 172.16.0.0/24 60.60.60.2 0 100 0 300 200 100 i
* i 172.17.0.0/24 40.40.40.2 0 100 0 100 200 i
* i 172.18.0.0/24 40.40.40.2 0 100 0 100 200 300 i
*> 172.19.0.0/24 0.0.0.0 0 32768 i
* i 192.168.10.0 40.40.40.2 0 100 0 100 200 300 i
*>i 192.168.30.0 60.60.60.2 0 100 0 i
2 Accepted Solutions
Jon Marshall
It is happening because vIOS2 and vIOS3 are receiving an IBGP route for 172.16.0.0/24 route from vIOS1 and so they cannot advertise that route to vIOS4 which is an IBGP peer.
Which means vIOS4 only gets a route advertisement from vIOS8 for that subnet.
Jon
vIOS1 receives an EBGP route for 172.16.0.0/24 and advertises it via IBGP to vIOS2 and vIOS3.
vIOS2 and vIOS3 cannot then advertise that route to vIOS because of the IBGP rule ie. a route received from an IBGP peer cannot be advertised to another IBGP peer.
Jon
Jon Marshall
Jon
Thank you for the reply.
However as you can see two paths going to 172.16.0.0/24 has been advertised to vIOS2 and vIOS3 the other path is thru vIOS4 as the eBGP peer. Why are the 2 paths not being learned in vIOS4 while learned in vIOS2 and vIOS3.
Thank you.
Jon
Appreciate your help Jon, routes are now being learned from diff paths after configuring route-reflector.
* i 172.16.0.0/24 50.50.50.1 0 100 0 100 i
* 192.168.10.1 0 300 200 100 i
Thanks for your help!
