BGP routing issue
rodonohu1
hi,
I'm having a problem with a new network i've added to my router. I've added a network 172.17.19.0/27 and 172.17.19.32/27... and have added the following SubInterface config for one of them:
interface FastEthernet0/0.5
description Voice Vlan
encapsulation dot1Q 5
ip address 172.17.19.2 255.255.255.224
no ip redirects
ip pim sparse-dense-mode
ip cgmp
no snmp trap link-status
standby 1 ip 172.17.19.1
standby 1 priority 105
standby 1 preempt
standby 1 track Serial0/1/0:0
I've added it to my BGP AS as below:
router bgp 65202
no synchronization
bgp log-neighbor-changes
network 10.200.200.0 mask 255.255.255.224
network 172.17.9.0 mask 255.255.255.0
network 172.17.10.0 mask 255.255.255.0
network 172.17.11.248 mask 255.255.255.248
network 172.17.19.0 mask 255.255.255.224
network 172.17.19.32 mask 255.255.255.224
aggregate-address 172.17.10.0 255.255.254.0 summary-only
also I've added the following ACL:
access-list 108 deny udp host 172.17.19.4 any eq 5000
access-list 108 permit ip 172.17.19.0 0.0.0.31 any
access-list 109 permit udp host 172.17.19.0 any eq 5000
But I can't acecss this network from another other router. Any idea what i'm missing. i'm not an expert on Routing.
Kevin Dorrell
Level 10
Level 10
If you do a show ip bgp in the neighboring router, can you see the new prefixes? Also, just to check, when you do show ip bgp summary, can you see the neighbors you are expecting?
In the neighboring routers, what do you get for show ip route 172.17.19.0?
Kevin Dorrell
Luxembourg
Hi Kevin,
I see this when i do a show ip bgp:
*> 172.17.9.0/24 0.0.0.0 0 32768 i
s> 172.17.10.0/24 0.0.0.0 0 32768 i
* i172.17.10.0/23 172.17.10.21 0 100 0 i
*> 0.0.0.0 32768 i
s> 172.17.11.248/29 0.0.0.0 0 32768 i
* i172.17.19.0/27 172.17.10.21 0 100 0 i
*> 0.0.0.0 0 32768 i
* i172.17.19.32/27 172.17.10.21 0 100 0 i
the neighbors seem normal. I've checked the same setup on another router in a different location,...these are 172.16.6.0 and it shows up as follows:
s> 172.16.5.0/24 0.0.0.0 0 32768 i
s> 172.16.6.0/28 0.0.0.0 0 32768 i
s> 172.16.6.16/28 0.0.0.0 0 32768 i
s> 172.16.6.32/28 0.0.0.0 0 32768 i
s> 172.16.8.0/24 0.0.0.0 0 32768 i
Could it be to do with the way I have HSRP set up?
guruprasadr
Level 7
Level 7
HI, [Do Rate if HELPS]
You should have missed the I-BGP routing:
What is the IGRP protocol you are using ?
Pls check was there any "ip route" command need to be added for internal route synchronization. Like,
ip route 172.17.19.0 255.255.255.224
Do Rate if HELPS
Best Regards,
Guru Prasad R
