BGP Routing Policies Effectiveness
turbo_engine26
Level 4
Level 4
I've noticed that in order for a routing policy to take effect, the bgp peer connection must be cleared first. This is not practical of course in production environment. For example, using route maps to filter a specific NLRI or to set community attributes or even a simple distribute list doesn't take effect at all unless i clear bgp peer connection.
Also, please note that after a routing policy configuration, i waited for about 5 minutes (very long time indeed) to see the effectiveness of the policy but nothing happened until i cleared the peer.
Is this the normal IOS behavior for BGP?
A.M.
Jon Marshall
It is normal to have tell the router to do something but you shouldn't need to reset the connection. Instead do this -
clear ip bgp soft out
this instructs the router to send the new routing information to the BGP neighbor without having to reset the connection. Full details -
http://www.cisco.com/en/US/products/ps6599/products_data_sheet09186a0080087b3a.html
Jon
Jon Marshall
Jon
I really thank you for such a fast response.
Yes, it is working now but i wonder why the book didn't mention that yet.
Thx
A.M.
