Loopback interface is not working with BGP
turbo_engine26
Level 4
Level 4
I configured Loopback0 interfaces on EBGP peers as shown below.
R1(config)#interface loopback 0
R1(config-if)#ip address 10.50.250.1 255.255.255.255
R1(config)#router bgp 50
R1(config-router)#neighbor 10.100.83.1 remote-as 100
R1(config-router)#neighbor 10.100.83.1 ebgp-multihop 2
R1(config-router)#neighbor 10.100.83.1 update-source loopback 0
R1(config)#ip route 10.100.83.1 255.255.255.255 serial 1/0
R2(config)#interface loopback 0
R2(config-if)#ip address 10.100.83.1 255.255.255.255
R2(config)#router bgp 100
R2(config-router)#neighbor 10.50.250.1 remote-as 50
R2(config-router)#neighbor 10.50.250.1ebgp-multihop 2
R2(config-router)#neighbor 10.50.250.1 update-source loopback 0
R2(config)#ip route 10.50.250.1 255.255.255.255 serial 1/0
However, i can't ping both loopback interfaces and no BGP connection established.
Appreciate your cooperation.
A.M.
Marwan ALshawi
First can you ping the next hop ip configured on the serial interfaces ? If yes then use the next hop ip configured in serial interface in the static route rather than using interface serial
And try to ping loopbacks sourcing the ping from the local loopback
Ping x.x.x.x source interface loopback0
Hope this help
5 Replies 5
Marwan ALshawi
Hope this help
There are no ip addresses configured in the serial interfaces. Just the loopbacks.
thats why it is not working
you need to have IPs in the serial interfaces and ping each other first
Marwan,
You solved the problem thx and sorry for the late repy. The case study that i am currently working on didn't mention any serial interfaces to be configured because the topic is about loopback interfaces only, therefore the author ommitted the use of serial interfaces in the case study.
Thx again.
A.M.
Hi Turbo,
You first need to establish NLRI and then check for BGP. Unless you have end to end layer 3 connectivity BGP won't work. As marwan pointed out you need to fist have IP's on the serial interfaces. If you are trying to do the same on a L3 switch then its different. You can have SVI's and have a trunk between the swithces and can peer on the vlan interfaces. In that case you dont need to confgure IP addresses on the trunks.
Kishore
