BGP RR
tahseen12
Has anyone tried configuring 2 RR's of same cluster as clients to each other.
Logically it should work as reflected routes from 1 RR to other RR will have cluster Id attached hence the peer RR will not accept the route.Any suggestion???
Harold Ritter
Mohammad,
Why do you want to configure these two RRs as clients of each others as any of the reflected routes will be rejected anyway? Can you please let us know what you are trying to achieve.
