BGP - RTBH in IX - route-policy
franko-f1
Hello everyone,
 we use the Cisco ASR9902.
i am trying to set up RTBH functionality for our configuration in an IXP (internet exchange point) with route-policy :
#show running-config router bgp
neighbor 2001:7f8:14::11
  remote-as 47200
  use session-group sg_nix
  password encrypted ***************************************
  description nix_routeserver
  address-family ipv6 unicast
   use af-group afg6_nix200k
#show bgp af-group afg6_nix200k configuration
af-group afg6_nix200k address-family IPv6 Unicast
  maximum-prefix 200000 75 60                     []
  next-hop-self                                   [a:afg6_nix  a:afg6_all]
  policy rp6_nix_in in                            [a:afg6_nix]
  policy rp6_nix_out out                          [a:afg6_nix]
#show running-config route-policy rp6_nix_in
  if (destination in pl6_default_ge128) and (community matches-any CM-NIX-RTBH) then
    set local-preference 666
    set next-hop 2001:7f8:14::250
    set community (no-export)
  elseif destination in pl6_own_le128 then
    drop
  elseif destination in pl6_default then
    drop
  elseif as-path in asps_lv_grupa then
    drop
  else
    set community cl_r1_nixcz
  endif
end-policy
#show running-config community-set CM-NIX-RTBH
  #CM to drop prefix from Nix peers for RTBH
  65535:666
end-set
#show running-config prefix-set pl6_default_ge128
  ::/0 ge 128
end-set
Now, from the RTBH network is send the request for block the IP 2a02:38:bbbb::10/128, but it seems, that our route-policy do not accept it. And i don't know, why.
Some /128 routes are received :
#show bgp ipv6 unicast neighbor 2001:7f8:14::11 routes | utility egrep expr '/128'
*  2a00:1238::1/128   2001:7f8:14::250
*  2a01:a040:ffff:ffff:ffff:ffff:ffff:6/128
*  2a02:38:bbbb::10/128
*  2a02:c98:ffff:fe05::666/128
#show bgp ipv6 unicast  2a02:38:bbbb::10/128 longer-prefixes
BGP router identifier 1.1.1.1, local AS number 000000
BGP generic scan interval 60 secs
Non-stop routing is enabled
BGP table state: Active
Table ID: 0xe0800000   RD version: 402410595
BGP main routing table version 402410595
BGP NSR Initial initsync version 189301 (Reached)
BGP NSR/ISSU Sync-Group versions 0/0
BGP scan interval 60 secs
Status codes: s suppressed, d damped, h history, * valid, > best
              i - internal, r RIB-failure, S stale, N Nexthop-discard
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network            Next Hop            Metric LocPrf Weight Path
                      2001:7f8:14::250
                                                    666      0 6881 i
*                     2001:7f8:14::250
                                                    666      0 6881 i
Processed 1 prefixes, 2 paths
#sh route ipv6 2a02:38:bbbb::10/128
% Network not in table
Routing entry for 2a02:38::/32
  Known via "bgp 000000", distance 20, metric 0
  Tag 6881, type external
  Installed Dec 19 10:15:25.377 for 5w1d
  Routing Descriptor Blocks
    fe80::a2b4:39ff:fe55:8eec, from 2001:7f8:14::11, via TwentyFiveGigE0/0/0/7.10, BGP external
      Route metric is 0
  No advertising protos.
I am attaching the presentation of NIX.cz, how the RTBH in IX works.
I would be very grateful for any contributions and answers. What i can check ?
Many thanks.
9 Replies 9
Harold Ritter
Hi @franko-f1 ,
I am not sure why you change the NH on your side, as it should have be changed by the RS already.
Can you attach the output from the "show bgp ipv6 unicast 2a02:38:bbbb::10/128" for us to see what is causing the prefix not to be selected as the BGP best path and therefore not being installed in the RIB.
Can you also provide a "show cef ipv6 2001:7f8:14::250" output.
franko-f1
Hi Harold,
sure, here are outputs for requested commands :
Tue Jan 28 13:22:42.748 CET
BGP routing table entry for 2a02:38:bbbb::10/128
Versions:
Process bRIB/RIB SendTblVer
Speaker 377528327 377528327
Last Modified: Nov 13 04:40:15.195 for 10w6d
Paths: (2 available, no best path)
Not advertised to any peer
Path #1: Received by speaker 0
6881
2001:7f8:14::250 from 2001:7f8:14::11 (91.210.16.1)
Origin IGP, localpref 666, valid, external
Received Path ID 0, Local Path ID 0, version 0
Community: no-export
Origin-AS validity: invalid
Path #2: Received by speaker 0
6881
2001:7f8:14::250 from 2001:7f8:14::12 (91.210.16.2)
#show cef ipv6 2001:7f8:14::250
Tue Jan 28 13:24:27.705 CET
2001:7f8:14::/64, version 277143721, attached, connected, internal 0x1000061 0x0 (ptr 0x7cc5c344) [1], 0x400 (0x9b3fe888), 0x0 (0x0)
 Updated Apr  2 19:41:13.182
 remote adjacency to TwentyFiveGigE0/0/0/7.10
 Prefix Len 64, traffic index 0, precedence n/a, priority 0
  gateway array (0x78b61890) reference count 1, flags 0x0, source rib (7), 0 backups
                [2 type 3 flags 0x8401 (0x78c14e20) ext 0x0 (0x0)]
  LW-LDI[type=3, refc=1, ptr=0x9b3fe888, sh-ldi=0x78c14e20]
  gateway array update type-time 1 Apr  2 19:41:13.182
 LDI Update time Apr  2 19:41:13.182
 LW-LDI-TS Apr  2 19:41:13.182
   via TwentyFiveGigE0/0/0/7.10, 312 dependencies, weight 0, class 0 [flags 0x8]
    path-idx 0 NHID 0x0 [0x788db890 0x0]
    remote adjacency
    Load distribution: 0 (refcount 2)
    Hash  OK  Interface                 Address
    0     Y   TwentyFiveGigE0/0/0/7.10  remote
Hi @franko-f1 ,
By default, IOS-XR validates that the AS path first hop (6881) is equal to the neighbor ASN (47200). This check fails if the prefix is received through a route server, as the route server does not insert its ASN in the AS path. The following command is therefore required in such a scenario.
  enforce-first-as disable
neighbor 2001:7f8:14::12
Hi @Harold Ritter,
many thanks for your help.
So, i set the enforce-first-as disable for the both neighbors, but nothing changed.
It still doesn't working :(.
Hi @franko-f1 ,
Can please provide the "show bgp ipv6 unicast 2a02:38:bbbb::10/128 bestpath-compare" output.
Hi @Harold Ritter ,
sure, here is output :
#show bgp ipv6 unicast 2a02:38:bbbb::10/128 bestpath-compare
Wed Jan 29 21:04:54.342 CET
Versions:
    Flags: 0x00000001+0x20000000;
Last Modified: Nov 13 04:40:15.195 for 11w0d
  Flags: 0x1000000000020001+0x00, import: 0x020
  6881
    2001:7f8:14::250 from 2001:7f8:14::11 (91.210.16.1), if-handle 0x00000000
  6881
    2001:7f8:14::250 from 2001:7f8:14::12 (91.210.16.2), if-handle 0x00000000
Hi @franko-f1 ,
The issue is that you have RPKI configure on that router and the /128 prefix injection goes against the RPKI policy. This can be seen in the output:
Can you provide the output for the following command:
show bgp rpki table ipv6 | in "20001:7f8:14"
franko-f1
Hi @Harold Ritter ,
yes, aaah, i configured RPKI before this project RTBH.....
#show bgp rpki table | in "2001:7f8:14"
Wed Jan 29 22:10:38.474 CET
No network in rpki table found.
Harold Ritter
Hi @franko-f1 ,
Sorry, I meant show bgp rpki table ipv6 | in "2a02:38:" .
