Bgp Scanner
vishwancc
Level 3
Level 3
Hi ALL,
Does any one have any idea on the amout of CPU a BGP scanner process will take.
I have Internet router with 3L routes and only 1 neighbor IBGP .
The router is 7513 and it take 60%.
Chao
Vishwa
8 Replies 8
francisco_1
Level 7
Level 7
depends on router bgp routing table i believe! so a router carrying a large Internet routing table bgp scanner might use more cpu. Once a minute, BGP scanner walks the BGP RIB table and performs important maintenance tasks. These tasks include checking the next-hop referenced in the router's BGP table and verifying that the next-hop devices can be reached. Thus, a large BGP table takes an equivalently large amount of time to be walked and validated.
Hi Francisco,
Thanks for the reply.
I know about what the BGP process will do.I am more intreasted to know how much and will enabling or disabling CEF have any effect on this ?
Chao
Vishwa
CEF and the BGP scanner process? In interaction as far as I know.
Hi Jose,
Why i asked this is since scanner procees check the next hop reachability along with other thing,so i wanted to know how it verifies the next HOP reachabitily,as far as i know it will just check the routing table for that,but jbust wanted to make sure there is no packet sen d using CEF.
Chao
Vishwa
Hello Vishwa,
you cannot disable CEF on a C7600 or GSR you could do it on a C7513 but it not recommended and it wouldn't help.
BGP scanning is the process of verifying the BGP next-hop of each prefix.
You may have a single neighbor but quite a lot of prefixes ( a full internet table is in the order of 300,000 routes nowdays)
There can be some enhancements like BGP next-hop tracking that could provide some cpu resources savings in BGP scanner.
Also consider to use a lower frequency of BGP scanning operation that would spread over time cpu usage
see
http://www.cisco.com/en/US/docs/ios/iproute/configuration/guide/irp_bgp_adv_features_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1056230
Hope to help
Giuseppe
Hello Giuseppe,
Its funny i have 7513 and CEF is disabled,the reason was when i enable it my process memory is getting chocked due to this CEF,so it is disabled.
The funny part is i have Interrupt using close to 40% of 97% CPU utilization and rest 50% is BGP scan process with no CEF,but after enabling CEF it was Interrup was 35% there was not much difference.
Chao
Vishwa
Hello Vishwa,
I've found a troubleshooting guide for BGP scanner causing high cpu
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00809d16f0.shtml
Hope to help
Giuseppe
Thanks Giuseppe,
I have already checked this link it only tells that CPU will go high due to scanning but how much there is no information , and i dont know how Cisco is expecting me to run the debug when the CPU is already running high on the core internet router.I have googled a lot but did not find antthing which give any precise vlaue or point in some direction to troubleshoot , moreover i cannot increase the scantime also from 60 sec to see some difference.
Chao
Vishwa
