bgp soft reconfiguration
carl_townshend
Hi all
I have seen the command bgp soft reconfiguration inbound and outbound,
can anyone explain what this command does? I have read up but cant understand how it works, also what does the inbound and outbound do ?
cheers
Carl
Peter Paluch
Hello Carl,
Aaah, my favourite topic
Would you mind checking the following threads? I tried to explain this topic several times and it pops up repeatedly. Of course, I am willing to re-explaing it again should these threads be insufficient - just let me know.
https://supportforums.cisco.com/message/829228#829228
https://supportforums.cisco.com/message/3523990#3523990
Best regards,
Peter
Hi ,
us I understand , when we add command "neighbor x.y.z.t soft-reconfiguration inbound " the router create database containing all advertised routes to neigbhor x.y.z.t , this command is useful when debugging BGP routes issues.
Hi Adnane,
Not advertised to but rather received from neighbor x.y.z.t.
The primary purpose of soft-configuration inbound was to allow changing the input policy without the need to tear down and reestablish the BGP peering with the neighbor. It was accomplished, principially, by storing all received prefixes unfiltered and unchanged, and subsequently filtering this "pristine" database with the input policies into another database. The fact that the router stores all received prefixes unfiltered may help in certain debugging situations, but in general, the soft-reconfig inbound is not primarily a debugging tool.
Best regards,
Peter
Thanks peter , i will correct my knowldge.
