bgp to the isp for dual internet routers to 2 isps
carl_townshend
Hi all
I have a quick qeustion about bgp to the isp
1.What do most customers do to influence the routing inbound to the company from the isp? AS Path prepend or MED ?
cheers
Carl
Hello Carl,
the MED cannot be passed to a third AS, unless the two ISPs have an agreement between themselves the MED would be not effective in your network scenario for inbound traffic
Hope to help
Giuseppe
6 Replies 6
Giuseppe Larosa
Hello Carl,
to influence how inbound traffic enters on the internet links AS path prepending is the more used tool.
MED can be used if the internet links connect to the same ISP AS in that case it is effective
Hope to help
Giuseppe
hi
so if you connect to different isp's cant you use the MED value ?
Hi, normaly no but there is the command bgp always-compare-med that permits to do so.
You could also use communities to influence inbound path by discussing with your ISP.
Regards.
Alain
Hello Carl,
Hope to help
Giuseppe
so
for same ISP use MED
for different ISP use AS path
can you give me a example config ?
Hello Carl,
you will need to apply route-maps outbound on eBGP sessions
router bgp
neighbor ISP1 route-map SETVALUES out
route-map SETVALUES permit 10
! match statement as needed
set as-path prepend
or for MED setting :
set metric
in case of AS path prepending you will prepend the ISP that you want to have a lower probability to be the return path
for MED you have to set on both neighbors with lower value that will be the preferred link for inbound traffic
see
http://www.cisco.com/en/US/docs/ios/11_3/np1/configuration/guide/1cbgp.html#wp14844
A good filter for routes to be advertised in multihoming is the following
ip as-path access-list 1 permit ^$
this matches an empty AS path attribute and allows to advertise only locally generated routes
in the route-map you would put in the match section
match as-path 1
this avoids to pass routes from ISP1 to ISP2 or from ISP2 to ISP1 to avoid to become a transit AS
Hope to help
Giuseppe
