BGP: Unable to announce route using the Network Statement
Anton Pestov
The host IP 84.204.x.x unable to announce through BGP
BGP configuration on Cisco 1841:
interface FastEthernet0.1201
encapsulation dot1Q 1201
ip address 172.18.11.1 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
crypto map vpn-map
service-policy output POLICY-IPVPN-8M-OUT
router bgp 65001
no synchronization
bgp router-id 192.168.255.11
bgp log-neighbor-changes
network 84.204.x.x mask 255.255.255.255
network 172.18.11.0 mask 255.255.255.252
redistribute eigrp 1 route-map RMAP-EIGRP-TO-BGP
redistribute rip route-map RMAP-RIP-TO-BGP
neighbor 172.18.11.2 remote-as 3216
neighbor 172.18.11.2 description *** ISP-PE Neighbor ***
neighbor 172.18.11.2 update-source FastEthernet0.1201
neighbor 172.18.11.2 route-map RMAP-AS-PREPEND2 out
no auto-summary
ip route 0.0.0.0 0.0.0.0 10.102.0.21
ip route 84.204.x.x 255.255.255.255 10.102.0.21 200
route-map RMAP-AS-PREPEND permit 10
set as-path prepend 65001 65001 65001
route-map RMAP-AS-PREPEND2 permit 5
match ip address prefix-list PFXL-LAN-IPVPN PFXL-LOOPBACK-IPVPN
route-map RMAP-AS-PREPEND2 permit 10
match ip address prefix-list PFXL-LAN PFXL-LOOPBACK
set as-path prepend 65000
route-map RMAP-AS-PREPEND2 permit 20
match ip address prefix-list PFXL-ANY
CE1#sh ip bgp
BGP table version is 1220, local router ID is 192.168.255.11
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
r> 0.0.0.0          172.18.11.2                            0 3216 65000 i
*> 10.0.0.0/23      172.18.11.2                            0 3216 65000 ?
*  10.0.0.0         172.18.11.2                            0 3216 65000 i
*>                  172.17.253.254          78         32768 ?
*> 10.102.0.0/23    0.0.0.0                 70         32768 ?
*> 10.202.20.0/23   172.18.11.2                            0 3216 65002 ?
*> 84.204.x.x/32 10.102.0.21              0         32768 i
*  172.18.11.0/30   172.18.11.2              0             0 3216 ?
*>                  0.0.0.0                  0         32768 i
*> 172.18.12.0/30   172.18.11.2                            0 3216 ?
CE1#sh ip bgp neighbors 172.18.11.2 advertised-routes
*> 10.0.0.0         172.17.253.254          78         32768 ?
*> 10.11.32.0/23    0.0.0.0         4294967295         32768 ?
*> 192.168.255.0    172.17.253.254          78         32768 ?
*> 192.168.255.11/32
                    0.0.0.0                  3         32768 ?
Total number of prefixes 5
Hello Anton,
modify the prefix-list
ip prefix-list PFXL-ANY seq 5 permit 0.0.0.0/0
as
ip prefix-list PFXL-ANY seq 5 permit 0.0.0.0/0 le 32
if the objective is to match any available IP prefix in BGP table
the route is present in the IP routing table and should be also in the BGP table so the issue is the prefix-list
Note:
you should prepend your own AS 65001 and not 65000
Hope to help
Giuseppe
Please check if the route for 84.204.x.x is available in the routing table. This is mandatory for the network command to work.Also please post the outputs of the prefix-lists. 'show run | in prefix-list' will help
Karthic
Hi, see ip route and prefix-lists below:
CE1#sh ip route 84.204.56.212
Routing entry for 84.204.56.212/32
  Known via "static", distance 200, metric 0
  Advertised by bgp 65001
  Routing Descriptor Blocks:
  * 10.102.0.21
      Route metric is 0, traffic share count is 1
CE1#show run | in prefix-list
ip prefix-list PFXL-DMVPN seq 5 permit 172.16.0.0/16 ge 24 le 24
ip prefix-list PFXL-DMVPN seq 10 permit 172.16.0.0/16 ge 32
ip prefix-list PFXL-GRE seq 5 permit 172.17.0.0/16 ge 30 le 30
ip prefix-list PFXL-IPVPN seq 5 permit 172.18.254.0/24 ge 30 le 30
ip prefix-list PFXL-IPVPN seq 10 permit 172.18.11.0/24 ge 30 le 30
ip prefix-list PFXL-IPVPN seq 15 permit 172.18.12.0/24 ge 30 le 30
ip prefix-list PFXL-IPVPN seq 20 permit 172.18.13.0/24 ge 30 le 30
ip prefix-list PFXL-LAN seq 4 permit 10.0.0.0/8
ip prefix-list PFXL-LAN seq 5 permit 10.0.0.0/8 ge 23 le 28
ip prefix-list PFXL-LAN-CO seq 5 permit 10.0.0.0/22 ge 23 le 28
ip prefix-list PFXL-LAN-CO seq 10 permit 10.100.0.0/22 ge 23 le 28
ip prefix-list PFXL-LAN-CO seq 15 permit 10.101.0.0/22 ge 23 le 28
ip prefix-list PFXL-LAN-CO seq 20 permit 192.168.252.0/24
ip prefix-list PFXL-LAN-IPVPN seq 5 permit 10.102.0.0/22 ge 23 le 28
ip prefix-list PFXL-LAN-IPVPN seq 10 permit 10.202.8.0/22 ge 23 le 28
ip prefix-list PFXL-LAN-IPVPN seq 15 permit 10.202.20.0/22 ge 23 le 28
ip prefix-list PFXL-LOOPBACK seq 4 permit 192.168.255.0/24
ip prefix-list PFXL-LOOPBACK seq 10 permit 192.168.255.0/24 ge 32
ip prefix-list PFXL-LOOPBACK-CO seq 5 permit 192.168.255.255/32
ip prefix-list PFXL-LOOPBACK-CO seq 10 permit 192.168.255.254/32
ip prefix-list PFXL-LOOPBACK-CO seq 15 permit 192.168.255.253/32
ip prefix-list PFXL-LOOPBACK-IPVPN seq 5 permit 192.168.255.11/32
ip prefix-list PFXL-LOOPBACK-IPVPN seq 10 permit 192.168.255.12/32
ip prefix-list PFXL-LOOPBACK-IPVPN seq 15 permit 192.168.255.13/32
Hello Anton,
as
Note:
Hope to help
Giuseppe
You are not matching the prefix in any of the prefix lists. Please add the command
ip prefix-list PFXL-ANY seq 20 permit 84.204.56.212/32
so that we can advertise this prefix
