bgp with default gateway
Peter Handke
Hello
There is small Data Center with bgp with a few  full feeds. There are some cons to set default routing to one of isp ? I don't advertise default routing anywhere, so there any reason to remove default routing ?
thank you for practical
advice
Pet
John Blakley
I may not understand the question fully, but the only reason for default routing is to be able to resolve networks that aren't directly in your routing table. If you never know what networks users will need to get to, then it's a good idea to have a default route on your router regardless if you push it down to your users or not.
HTH,
John
HTH, John *** Please rate all useful posts ***
