eigrp stub, connected route not redistributed !
davidmagniez
I have a strange problem happening in my topology I can't reproduce in labs :
Some directly connected route are not redistributed to eigrp, wheras it's configured to.
I have 3 locations with  2 stacked switchs c3750E 12.2(53)SE2 (UNIVERSALK9) ipbase
Theses 3 stacks are full mesh, interconnected by 2 independant networks : vlan64 and vlan65
I don't know the technlogy used for these interconnection, cause it's a link layer 2 subscribed to a provider.
Vlan 65 is down, cause the link is not operational now.
The main objective for that, is to be able to join each location with a redundant link. For us, EIGRP was the best choice...
here is a schema, much more explicit :
For workaround, we have put static route for each FW-SW interco (underlined by ** in the conf), If we don't do that, each FW-SW interco are not recognized by neighbor switchs, and not part of the routing tab.
here is the conf :
SW1#sh run | begin router
router eigrp 100
variance 2
network 192.168.64.0
network 192.168.65.0
redistribute static
redistribute connected
passive-interface default
no passive-interface Vlan64
no passive-interface Vlan65
eigrp stub connected static
ip default-gateway 192.168.62.1
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.62.1
ip route 10.10.0.0 255.255.0.0 192.168.62.1
ip route 10.200.211.0 255.255.255.0 192.168.62.1
ip route 10.200.212.0 255.255.255.0 192.168.62.1
ip route 92.103.128.80 255.255.255.240 192.168.62.1
ip route 192.168.0.0 255.255.255.0 192.168.62.1
ip route 192.168.31.0 255.255.255.248 192.168.62.1
ip route 192.168.32.0 255.255.255.248 192.168.62.1
ip route 192.168.33.0 255.255.255.248 192.168.62.1
ip route 192.168.34.0 255.255.255.248 192.168.62.1
ip route 192.168.41.0 255.255.255.0 192.168.62.1
ip route 192.168.42.0 255.255.255.0 192.168.62.1
ip route 192.168.52.0 255.255.255.0 192.168.62.1
ip route 192.168.54.0 255.255.255.0 192.168.62.1
ip route 192.168.55.0 255.255.255.0 192.168.62.1
**ip route 192.168.60.0 255.255.255.224 192.168.64.3**
ip route 192.168.81.0 255.255.255.0 192.168.62.1
ip route 192.168.140.0 255.255.255.0 192.168.62.1
ip route 192.168.246.0 255.255.255.0 192.168.62.1
SW_1#sh run | begin Vlan62
interface Vlan62
ip address 192.168.62.2 255.255.255.224
interface Vlan64
description INTERCO_200
bandwidth 200000
ip address 192.168.64.2 255.255.255.224
interface Vlan65
bandwidth 100000
ip address 192.168.65.2 255.255.255.224
shutdown
and for interfaces :
interface GigabitEthernet1/0/48
description VL_L2LB
switchport trunk native vlan 64
switchport trunk allowed vlan 64
switchport mode trunk
shutdown
interface GigabitEthernet1/1/1
description VL_L2LB
switchport trunk allowed vlan 65
====SW2=====
SW2#sh run | begin router
router eigrp 100
variance 2
redistribute static
ip default-gateway 192.168.60.1
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.60.1
ip route 192.168.22.0 255.255.255.0 192.168.60.1
ip route 192.168.50.0 255.255.255.0 192.168.60.1
ip route 192.168.57.0 255.255.255.0 192.168.60.1
**ip route 192.168.62.0 255.255.255.224 192.168.64.2**
ip route 192.168.80.0 255.255.255.0 192.168.60.1
SW2#sh run | begin Vlan60
interface Vlan60
ip address 192.168.60.2 255.255.255.224
interface Vlan64
description VL_INTER_CIV
bandwidth 200000
ip address 192.168.64.3 255.255.255.224
interface Vlan65
bandwidth 100000
ip address 192.168.65.3 255.255.255.224
description VL_L2LA
duplex full
interface GigabitEthernet2/0/48
description L2LB
switchport trunk native vlan 65
switchport trunk allowed vlan 65,200
=====SW 3=====
SW3#sh run | begin router
router eigrp 100
variance 2
redistribute static
ip default-gateway 192.168.62.2
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.62.2
ip route 192.168.6.0 255.255.255.0 192.168.61.1
ip route 192.168.20.0 255.255.255.0 192.168.61.1
ip route 192.168.56.0 255.255.255.0 192.168.61.1
ip route 192.168.148.0 255.255.255.0 192.168.61.1
ip route 212.27.38.253 255.255.255.255 192.168.61.1
SW3#sh run | begin Vlan24
interface Vlan24
description VL_USER
ip address 192.168.24.1 255.255.252.0
ip helper-address 192.168.51.10
interface Vlan61
description VL_INTERCO
ip address 192.168.61.2 255.255.255.248
interface Vlan64
bandwidth 200000
ip address 192.168.64.1 255.255.255.224
interface Vlan65
description INTERCO_100
bandwidth 100000
ip address 192.168.65.1 255.255.255.224
shutdown
description L2L IBM
description L2LB
here is some show :
SW2#sh ip eigrp nei
EIGRP-IPv4 Neighbors for AS(100)
H   Address                 Interface       Hold Uptime   SRTT   RTO  Q  Seq
                                            (sec)         (ms)       Cnt Num
0   192.168.64.2            Vl64              11 4d20h      22   200  0  571
1   192.168.64.1            Vl64              13 4d20h      13   200  0  969
SW2#sh ip route 192.168.62.0 255.255.255.224
Routing entry for 192.168.62.0/27
  Known via "static", distance 1, metric 0
  Redistributing via eigrp 100
  Advertised by eigrp 100
  Routing Descriptor Blocks:
  * 192.168.64.2
      Route metric is 0, traffic share count is 1
SW2#sh ip eigrp top 192.168.62.0/27
EIGRP-IPv4 Topology Entry for AS(100)/ID(192.168.65.3) for 192.168.62.0/27
  State is Passive, Query origin flag is 1, 1 Successor(s), FD is 13056
  Descriptor Blocks:
  192.168.64.2, from Rstatic, Send flag is 0x0
      Composite metric is (13056/0), route is External
      Vector metric:
        Minimum bandwidth is 200000 Kbit
        Total delay is 10 microseconds
        Reliability is 255/255
        Load is 1/255
        Minimum MTU is 9000
        Hop count is 0
        Originating router is 192.168.65.3
      External data:
        AS number of route is 0
        External protocol is Static, external metric is 0
        Administrator tag is 0 (0x00000000)
  192.168.64.1 (Vlan64), from 192.168.64.1, Send flag is 0x0
      Composite metric is (13312/13056), route is External
      Vector metric:
        Total delay is 20 microseconds
        Load is 1/255
        Minimum MTU is 9000
        Hop count is 1
        Originating router is 192.168.80.1
      External data:
that's quite normal, as route is put static, but if route is not put static, we have something like :
EIGRP-IPv4 Topology Entry for AS(100)/ID(192.168.64.3)
%Entry 192.168.62.0/27 not in topology table
and If I'm not wrong, there should be an output of the redistributed connected route, before the redistributed static route by 64.1, cause connected route as a lower metric than static ?!
here is the concerned route on SW1, all seems to be ok :
SW1#sh ip route 192.168.62.0
Routing entry for 192.168.62.0/27, 1 known subnets
  Attached (1 connections)
C       192.168.62.0 is directly connected, Vlan62
but topology from this switch should not be that ! (ie redistribute connected route should be in first place ?!, here it is entirely missing !)
SW1#sh ip eigrp top 192.168.62.0/27
EIGRP-IPv4 Topology Entry for AS(100)/ID(192.168.65.2) for 192.168.62.0/27
  State is Passive, Query origin flag is 1, 0 Successor(s), FD is 4294967295
  Descriptor Blocks:
      Vector metric:
        Load is 1/255
        Minimum MTU is 9000
        Hop count is 1
      External data:
  192.168.64.3 (Vlan64), from 192.168.64.3, Send flag is 0x0
      Vector metric:
        Load is 1/255
        Minimum MTU is 9000
        Hop count is 1
      External data:
And now, with a network connected /29, on the other switch, it's working !
SW2#sh ip route 192.168.61.0 255.255.255.248
Routing entry for 192.168.61.0/29
  Known via "eigrp 100", distance 170, metric 13312, type external
  Last update from 192.168.64.1 on Vlan64, 4d20h ago
  * 192.168.64.1, from 192.168.64.1, 4d20h ago, via Vlan64
      Route metric is 13312, traffic share count is 1
      Total delay is 20 microseconds, minimum bandwidth is 200000 Kbit
      Reliability 255/255, minimum MTU 9000 bytes
      Loading 1/255, Hops 1
SW2#sh ip eigrp top 192.168.61.0/29
EIGRP-IPv4 Topology Entry for AS(100)/ID(192.168.65.3) for 192.168.61.0/29
  State is Passive, Query origin flag is 1, 1 Successor(s), FD is 13312
  Descriptor Blocks:
      Composite metric is (13312/2816), route is External
      Vector metric:
        Load is 1/255
        Minimum MTU is 9000
        Hop count is 1
      External data:
        External protocol is Connected, external metric is 0
same as for another directly connected network in the same neighbor :
SW2#sh ip eigrp top 192.168.24.0/22
EIGRP-IPv4 Topology Entry for AS(100)/ID(192.168.65.3) for 192.168.24.0/22
  Descriptor Blocks:
      Vector metric:
        Load is 1/255
        Minimum MTU is 9000
        Hop count is 1
      External data:
few other questions :
- why redistributed connected route are not advertised correctly on eigrp on some neighbors ?
- should be connected route, mentionned with "network X.X.X.X" command to be internal, is it good ??
- is it a best practice to enforce metric by specifying it with "redistribute static metric 100000 100 255 1 1500" ?
- I think "default metric" is not useful here cause we don't redistribute another routing protocol into eigrp, am I right ?
Thanks for your investigations !
cadet alain
1) all is perfectly normal on sw1 and sw3 you'll see your connected routes from sw2 redistributed into EIGRP appear as D EX  but I think you have to set a metric for static routes , do they appear in the routing table of other switches as D EX ?
2)yes you can also do it this way as in IPv4 redistribution there is a include-connected default behaviour
3-4) you can specify seed metric both ways but first way will overide second way and I think you can't redistribute static into EIGRP without a seed metric
Regards.
Alain.
Hi alain,
Thanks for your fast reply,
I don't have to specify metric for static route, as all static route are well distributed over EIGRP (see below)
SW1#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.62.1 to network 0.0.0.0
     192.168.62.0/27 is subnetted, 1 subnets
D EX 192.168.148.0/24 [170/13312] via 192.168.64.1, 5d01h, Vlan64
     192.168.31.0/29 is subnetted, 1 subnets
S       192.168.31.0 [1/0] via 192.168.62.1
     192.168.61.0/29 is subnetted, 1 subnets
D EX    192.168.61.0 [170/13312] via 192.168.64.1, 5d01h, Vlan64
D EX 192.168.15.0/24 [170/13312] via 192.168.64.1, 5d01h, Vlan64
     192.168.60.0/27 is subnetted, 1 subnets
S       192.168.60.0 [1/0] via 192.168.64.3
S    192.168.42.0/24 [1/0] via 192.168.62.1
S    192.168.246.0/24 [1/0] via 192.168.62.1
D EX 192.168.57.0/24 [170/13312] via 192.168.64.3, 5d01h, Vlan64
D EX 192.168.56.0/24 [170/13312] via 192.168.64.1, 5d01h, Vlan64
S    192.168.41.0/24 [1/0] via 192.168.62.1
S    192.168.140.0/24 [1/0] via 192.168.62.1
     192.168.64.0/27 is subnetted, 1 subnets
C       192.168.64.0 is directly connected, Vlan64
S    192.168.81.0/24 [1/0] via 192.168.62.1
S    192.168.55.0/24 [1/0] via 192.168.62.1
D EX 192.168.80.0/24 [170/13312] via 192.168.64.3, 5d01h, Vlan64
     192.168.65.0/27 is subnetted, 1 subnets
D       192.168.65.0 [90/26112] via 192.168.64.3, 5d01h, Vlan64
     92.0.0.0/28 is subnetted, 1 subnets
S       92.103.128.80 [1/0] via 192.168.62.1
S    192.168.54.0/24 [1/0] via 192.168.62.1
D EX 192.168.20.0/24 [170/13312] via 192.168.64.1, 5d01h, Vlan64
     10.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
S       10.10.0.0/16 [1/0] via 192.168.62.1
S       10.200.211.0/24 [1/0] via 192.168.62.1
S       10.200.212.0/24 [1/0] via 192.168.62.1
D EX 192.168.6.0/24 [170/13312] via 192.168.64.1, 5d01h, Vlan64
D EX 192.168.53.0/24 [170/13312] via 192.168.64.1, 5d01h, Vlan64
D EX 192.168.22.0/24 [170/13312] via 192.168.64.3, 5d01h, Vlan64
S    192.168.52.0/24 [1/0] via 192.168.62.1
     192.168.34.0/29 is subnetted, 1 subnets
S       192.168.34.0 [1/0] via 192.168.62.1
D EX 192.168.51.0/24 [170/13312] via 192.168.64.1, 5d01h, Vlan64
S    192.168.0.0/24 [1/0] via 192.168.62.1
     212.27.38.0/32 is subnetted, 1 subnets
D EX    212.27.38.253 [170/13312] via 192.168.64.1, 5d01h, Vlan64
D EX 192.168.50.0/24 [170/13312] via 192.168.64.3, 5d01h, Vlan64
     192.168.32.0/29 is subnetted, 1 subnets
S       192.168.32.0 [1/0] via 192.168.62.1
     192.168.33.0/29 is subnetted, 1 subnets
S       192.168.33.0 [1/0] via 192.168.62.1
S*   0.0.0.0/0 [1/0] via 192.168.62.1
D EX 192.168.24.0/22 [170/13312] via 192.168.64.1, 5d01h, Vlan64
As you can see, all static route are "D EX", but route to .60.0 is "S" (normal, cause i put it as static for workaround). route to .61 is good : "D EX".
If I delete my static route to .60.0 from SW1 and SW3, there will be no route to this network, (it should be, through EIGRP with SW2 redistribute connected).
Same happening for network 60.0 and 62.0 from every neighbor switch !
I test it in my lab, putting an additional static route to already defined "D EX" eigrp route.
I see all 3 route : 1 static and 2 other connected route !
comparing with my production topology, connected route are well recognized.
SW1_test#sh ip eigrp top 192.168.60.0/27
IP-EIGRP (AS 100): Topology entry for 192.168.60.0/27
  State is Passive, Query origin flag is 1, 1 Successor(s), FD is 15360
  192.168.64.3, from Rstatic, Send flag is 0x0
      Composite metric is (15360/0), Route is External
      Vector metric:
        Total delay is 100 microseconds
        Load is 1/255
        Minimum MTU is 1500
        Hop count is 0
      External data:
        Originating router is 192.168.65.2 (this system)
      Composite metric is (30720/28160), Route is External
      Vector metric:
        Minimum bandwidth is 100000 Kbit
        Total delay is 200 microseconds
        Load is 1/255
        Minimum MTU is 1500
        Hop count is 1
      External data:
  192.168.65.3 (Vlan65), from 192.168.65.3, Send flag is 0x0
      Vector metric:
        Load is 1/255
        Minimum MTU is 1500
        Hop count is 1
      External data:
I emulate 2600 series (2600 Software (C2691-ADVIPSERVICESK9-M), Version 12.4(17)) with 16FE-SW module in GNS3
Here is some log event, I removed all concerned route after putting static route
SW2#sh ip eigrp event
---all after static route inserted---
94   14:11:15.269 Metric set: 192.168.62.0/27 4294967295
95   14:11:15.269 Redist rt event: Route Up
96   14:11:15.269 Redist rt change: 192.168.62.0/27 Rstatic
97   14:09:56.335 Metric set: 192.168.60.0/27 4294967295
98   14:09:56.335 Poison squashed: 192.168.60.0/27 metric chg
99   14:09:56.335 Route installing: 192.168.60.0/27 192.168.64.2
100  14:09:56.335 Find FS: 192.168.60.0/27 4294967295
101  14:09:56.335 Rcv update met/succmet: 13312 13056
102  14:09:56.335 Rcv update dest/nh: 192.168.60.0/27 192.168.64.2
103  14:09:56.335 Metric set: 192.168.60.0/27 4294967295
104  14:06:01.565 Change queue emptied, entries: 17
The switch put the biggest metric he can (integer limit) : 4294967295, amazing !
