BGP won't re-establish thru GRE/IPSec tunnel when intenet circuit bounces
Presgar
I have a Cisco 3825 on the inside of an ASA 5505.  The 5505 has an IPSEC tunnel to an ASA5520.  I only allow loopback to looback traffic thru the tunnel.
I have a tunnel interface setup on each 3825 that comes up and BGP establishes a neighbor relationship.  All works great.  Then The internet circuit goes down, and then back up.  My IPSec tunnel comes back up, I can ping the loopbacks from each other, but BGP won't connect.  I have tried to shut the tunnel interfaces off on both sides, but I end up having to reboot the remote 3825, the one behind the 5505.  BGP establishes its neighbor relationship and all is well again.  Any idea how I can get BGP to re-establish it relationship and learn the routes?
My configs are very basic.  I can share if you need them.  I have this same scenario with 20 remote locations using 5505s and 2800 and 3800 series routers.  This router happens to have 15.01 installed.
6 Replies 6
rizwanr74
Level 7
Level 7
Hi Seth,
"My IPSec tunnel comes back up, I can ping the loopbacks from each other, but BGP won't connect."
When BGP does not come again, will you be able to ping the remote loopback by sourcing ping from local loopback?
Do you have on either side of the ASAes have IPS-module doing deep-packet inspection?
Rizwan Rafeek.
Rizwan,
Thanks for your reply.
Yes, I can ping the tunnel's destination loopback from the tunnels source loopback interface. I can do this on both routers.
We don't use IPS modules at this time.  It is a strange issue.  Is there any config that you would like to see on the 3825s or ASAs?
Hi Seth,
bgp peering is sourced to which interface?
Have you tried bgp peering sourced to tunnel interface?
Vishesh Verma
Hi Seth,
Please check the MTU, MSS for BGP neighbor
show interface | MTU
show ip bgp neighbor | i segment
Manually check the MTU size for the link. (Use extended ping)
If possible, please post following from the router -
show ip bgp summary | i InQ|
show log | i BGP
Here are the outputs.  The commands were ran when BGP is working properly.  The Gre Tunnles are passing BGP messages and routing is fine.  I only have the issue when the IPSec tunnle between the 2 ASAs go down.
Here is an extended ping output with DF set and MTU set at 1500
Atlntc3825NY#ping
Protocol [ip]:
Target IP address: 192.168.179.21
Repeat count [5]: 2
Datagram size [100]: 1500
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: loopb        4
Type of service [0]:
Set DF bit in IP header? [no]: y
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 2, 1500-byte ICMP Echos to 192.168.179.21, timeout is 2 seconds:
Packet sent with a source address of 192.168.179.21
Packet sent with the DF bit set
Success rate is 100 percent (2/2), round-trip min/avg/max = 1/1/1 ms
Atlntc3825NY#
This is the router that has to be rebooted.  Its a 3825.
Atlntc3825NY#sh interfaces tunnel 0
Tunnel0 is up, line protocol is up
  Hardware is Tunnel
  Description: GRE to Huntington
  Internet address is 192.168.30.102/30
  MTU 17916 bytes, BW 100000 Kbit/sec, DLY 50000 usec,
  Encapsulation TUNNEL, loopback not set
  Keepalive not set
  Tunnel source 192.168.179.21 (Loopback4), destination 192.168.255.50
   Tunnel Subblocks:
      src-track:
         Tunnel0 source tracking subblock associated with Loopback4
          Set of tunnels with source Loopback4, 1 member (includes iterators), on i
BGP neighbor is 192.168.30.101,  remote AS 65001, external link
  BGP version 4, remote router ID 192.168.255.51
  BGP state = Established, up for 19:39:20
  Last read 00:00:46, last write 00:00:18, hold time is 180, keepalive interval is 60 seconds
  Neighbor sessions:
    1 active, is multisession capable
  Neighbor capabilities:
    Route refresh: advertised and received(new)
    Four-octets ASN Capability: advertised and received
    Address family IPv4 Unicast: advertised and received
    Multisession Capability: advertised and received
  Message statistics, state Established:
    InQ depth is 0
    OutQ depth is 0
                         Sent       Rcvd
    Opens:                  1          1
    Notifications:          0          0
    Updates:               34         38
    Keepalives:          1299       1292
    Route Refresh:          0          0
    Total:               1334       1331
  Default minimum time between advertisement runs is 30 seconds
For address family: IPv4 Unicast
  Session: 192.168.30.101 session 1
  BGP table version 383, neighbor version 383/0
  Output queue size : 0
  Index 1
  1 update-group member
                                 Sent       Rcvd
  Prefix activity:               ----       ----
    Prefixes Current:             367        354 (Consumes 18408 bytes)
    Prefixes Total:               369        366
    Implicit Withdraw:              2          2
    Explicit Withdraw:              0         10
    Used as bestpath:             n/a        168
    Used as multipath:            n/a          0
                                   Outbound    Inbound
  Local Policy Denied Prefixes:    --------    -------
    AS_PATH loop:                       n/a         13
    Invalid Path:                         9        n/a
    Total:                                9         13
  Number of NLRIs in the update sent: max 105, min 0
  Address tracking is enabled, the RIB does have a route to 192.168.30.101
  Connections established 1; dropped 0
  Last reset never
  Transport(tcp) path-mtu-discovery is enabled
  Graceful-Restart is disabled
Connection state is ESTAB, I/O status: 1, unread input bytes: 0
Connection is ECN Disabled, Mininum incoming TTL 0, Outgoing TTL 1
Local host: 192.168.30.102, Local port: 59287
Foreign host: 192.168.30.101, Foreign port: 179
Connection tableid (VRF): 0
Maximum output segment queue size: 50
Enqueued packets for retransmit: 0, input: 0  mis-ordered: 0 (0 bytes)
Event Timers (current time is 0x438EA5C):
Timer          Starts    Wakeups            Next
Retrans          1333         24             0x0
TimeWait            0          0             0x0
AckHold          1304       1280             0x0
SendWnd             0          0             0x0
KeepAlive           0          0             0x0
GiveUp              0          0             0x0
PmtuAger       227887     227886       0x438EB37
DeadWait            0          0             0x0
Linger              0          0             0x0
ProcessQ            0          0             0x0
iss: 2931119445  snduna: 2931147525  sndnxt: 2931147525     sndwnd:  15890
irs:  840568039  rcvnxt:  840596200  rcvwnd:      15719  delrcvwnd:    665
SRTT: 300 ms, RTTO: 303 ms, RTV: 3 ms, KRTT: 0 ms
minRTT: 12 ms, maxRTT: 300 ms, ACK hold: 200 ms
Status Flags: active open
Option Flags: nagle, path mtu capable
IP Precedence value : 6
Datagrams (max data segment is 1436 bytes):
Rcvd: 2640 (out of order: 0), with data: 1306, total data bytes: 28160
Sent: 2629 (retransmit: 24, fastretransmit: 0, partialack: 0, Second Congestion: 0), with data: 1310, total data bytes: 28079
Packets received in fast path: 0, fast processed: 0, slow path: 0
fast lock acquisition failures: 0, slow path: 0
The next output shows a 2 neighbors.  I do have 2 seperate IPSec Tunnels working on the firewall, each going to a different Data center.  I have the same GRE/IPSec with BGP configuration for both.  I get the same issue with both FRE tunnels and BGP.
Atlntc3825NY#sh ip bgp summary
BGP router identifier 192.168.179.25, local AS number 65016
BGP table version is 383, main routing table version 383
367 network entries using 44040 bytes of memory
725 path entries using 37700 bytes of memory
48/29 BGP path/bestpath attribute entries using 5952 bytes of memory
22 BGP AS-PATH entries using 528 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP using 88220 total bytes of memory
BGP activity 376/9 prefixes, 736/11 paths, scan interval 60 secs
Neighbor        V           AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
10.11.252.49    4        64999    1333    1330      383    0    0 19:41:57      354
192.168.30.101  4        65001    1334    1337      383    0    0 19:41:57      354
Atlntc3825NY#
This command was run after a rebot and while BGP is working fine.  The log was cleaned out of all messages.
Atlntc3825NY#sh log | i BGP
000303: *Oct 29 18:16:28.524: %BGP-5-ADJCHANGE: neighbor 192.168.30.101 Up
000304: *Oct 29 18:16:28.584: %BGP-5-ADJCHANGE: neighbor 10.11.252.49 Up
Atlntc3825NY#
This is the core router in my data center, I ran the same sh commands.
ATLHunt3825#sh int tunnel 9
Tunnel9 is up, line protocol is up
  Hardware is Tunnel
  Description: GRE Tunnel to Atlantic Babylon
  Internet address is 192.168.30.101/30
  MTU 17916 bytes, BW 10000 Kbit/sec, DLY 50000 usec,
     reliability 255/255, txload 4/255, rxload 3/255
  Keepalive not set
  Tunnel source 192.168.255.50 (Loopback1), destination 192.168.179.21
   Tunnel Subblocks:
      src-track:
         Tunnel9 source tracking subblock associated with Loopback1
          Set of tunnels with source Loopback1, 1 member (includes iterators), on interface
  Tunnel protocol/transport GRE/IP
    Key disabled, sequencing disabled
    Checksumming of packets disabled
  Tunnel TTL 255, Fast tunneling enabled
  Tunnel transport MTU 1476 bytes
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
  Last input 00:00:02, output 00:00:34, output hang never
  Last clearing of "show interface" counters 10w1d
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 153681
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
  30 second input rate 125000 bits/sec, 70 packets/sec
  30 second output rate 163000 bits/sec, 72 packets/sec
     158948538 packets input, 1976205449 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     168717490 packets output, 3284828058 bytes, 0 underruns
     0 unknown protocol drops
Any ideas?
Hi Seth,
It might be an issue of tunnels. Check if drop counter is incrementing when BGP is down. "output drops: 153681"
Turn on the keepalive on tunnel. See if tunnel comes back up after the IPSec reset.
Also, take some packet captures on the ASA inside interface to see if BGP/TCP packets are going across.
Look at the ouput of show tcp brief; If you see LISTEN on BGP peer then I am guessing bgp traffic is not passing through.
Debugs can show you more insight of the problem -
debug ip bgp
debug ip tcp transactions
-Vishesh
