01-02-2009 07:28 PM - edited 03-04-2019 03:18 AM
I am studying for the CCNP and I am setting up a simple BGP connection between two routers but can't get it to work.
Here are the configs.
<RTR_A>-------<switch>------<RTR_B>
Router A
int lo0
ip add 10.10.10.10 255.255.255.255
int fa0/0
ip add 192.168.0.1 255.255.255.252
router bgp 1
neighbor 192.168.0.2 remote-as 2
Router B
int lo0
ip add 20.20.20.20 255.255.255.255
int fa0/0
ip add 192.168.0.2 255.255.255.252
router bgp 2
neighbor 192.168.0.1 remote-as 1
Any reason why this isn't connecting? Physical layer is good as I can ping connected interfaces from both sides.
Richard
01-02-2009 07:54 PM
Ahh ... figured it out. Have to advertise networks as well as name neighbors in router bgp
01-03-2009 05:10 AM
Hello Richard,
a useful command is
sh ip bgp summary
as you have just discovered is possible to build a BGP session without advertising nothing.
in this case you see 0 as the number of prefixes received.
If you use sh ip route bgp you don't see nothing but the BGP session is up.
Think of BGP session as a communication channel between two devices
Hope to help
Giuseppe
