BGPv6
LLPMRCISCO
Greetings,
I have weird problem for me, which could be very simple for somebody else. I'm not new with IPv6, however I am quite new with BGP.
Here is the scenario:
I establish IPv6 bgp neighbor, see all the routes, can ping IPv6 internet all from the routers outside interface. However, I can not ping it from inside interface. I can ping static defined IPv6 routes from inside interface.
On this router I am running IPv4 and IPv6, however BGP is only for IPv6.
My site prefix is:
2001:67C:1328::/48 , BGP neighbour is 2A01:260:1::210.
Here is the IPv6 configuration: I deleted rest of the config regarding IPv4.
ipv6 unicast-routing
ipv6 cef
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio1
no ip address
shutdown
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
interface FastEthernet0
no ip address
duplex auto
speed auto
interface FastEthernet0.26
encapsulation dot1Q 26
interface FastEthernet0.27
encapsulation dot1Q 27
ipv6 address 2001:67C:1328:67::2/64
ipv6 enable
interface FastEthernet1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet2
switchport access vlan 2
interface FastEthernet3
switchport access vlan 3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
no ip address
interface Vlan2
interface Vlan3
ipv6 address 2A01:260:8039::2/126
ipv6 enable
router bgp 199268
bgp router-id 1.1.1.1
no bgp default ipv4-unicast
bgp log-neighbor-changes
neighbor 2A01:260:1::210 remote-as 34779
neighbor 2A01:260:1::210 description Connection to ISP
neighbor 2A01:260:1::210 ebgp-multihop 5
address-family ipv4
  no auto-summary
exit-address-family
address-family ipv6
  redistribute static
  network 2001:67C:1328::/48
  neighbor 2A01:260:1::210 activate
  neighbor 2A01:260:1::210 default-originate
  neighbor 2A01:260:1::210 prefix-list ISP out
exit-address-family
logging esm config
ipv6 route 2001:67C:1328:66::/64 2001:67C:1328:67::1
ipv6 route 2001:67C:1328::/48 Null0
ipv6 route 2A01:260:1::210/128 2A01:260:8039::1
ipv6 prefix-list ISP seq 5 permit 2001:67C:1328::/48
end
Any input would be greatly appreciated.
It looks good. You are definitely advertising your prefix to your ISP. You need to talk to your ISP to find out why your prefix does not seem to make it to the Internet.
6 Replies 6
Seb Rupik
just to clarify, the 'outside' interface that gives you access to exernal IPv6 address is the VLAN3 SVI? Which 'inside' interface are you attempting to ping from?
cheers,
Seb.
Thank you for interest.
Yes, VLAN 3 SVI gives external access. I am attempting to ping from IPv6 address from the router (2001:67C:1328:67::2/64) .
Ping 2001:4860:4860::8888 (google dns) works, Ping 2001:4860:4860::8888 source 2001:67C:1328:67::2 does not work.
Ping to neighbor 2A01:260:1::210 works even from the inside ( I believe because of the static IPv6 route).
I looked up your prefix (2001:67C:1328::/48) from several looking glass servers on the Internet and could not find it. It does not appear that your prefix is properly propagated. Your configuration looks good, except for the fact that you advertise the default route to your ISP ("neighbor 2A01:260:1::210 default-originate"). The issue might be with your ISP.
Can you post the output for the following command:
show bgp ipv6 unicast neighbor 2A01:260:1::210 advertised-routes
HI,
My first configuration was without default originate (did not work as well), this is someting I added just for trying purposes. Have deleted this command now.
This is output:
Zunanji1#show bgp ipv6 unicast neighbor 2A01:260:1::210 advertised-routes
BGP table version is 10587, local router ID is 1.1.1.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale, m multipath, b backup-path, x best-external
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 2001:67C:1328::/48
                    ::                       0         32768 i
Total number of prefixes 1
Problem solved, ISP fault.
