block all traffic except
j_Pearcy00
I am trying to block all outbound traffic except for certain ports. I tried
access-list 101 permit tcp any any eq www
access-list 101 permit tcp any any eq 443
access-list 101 permit tcp any any eq smtp
access-list 101 permit tcp any any eq pop3
access-list 101 permit tcp any any eq 53
access-list 101 permit ip any any
access-list 101 deny tcp any any
that dosent stop anything. I tried
That stops everything. Any help would be great. Thanks
6 Replies 6
sacker12345
Access-list flow down so you put the most specific at the top and generalized ones at the bottom. On your first list you have permit ip any any which makes nothing blocked.
And if im not mistaken dns uses UDP also which is blocked in the second list.
Joseph W. Doherty
Beside Kyle's post, where are you using this ACL, inside facing interface or outside facing interface? Also, in or out on the interface?
Reason I ask, with the explicit deny tcp any and the implicit deny all, your ACL needs to match the destination's port. I.e. the difference between inside in and outside out vs. inside out and outside in.
I am planning on applying this ACL to a fast ethernet port on the inside. So inside out.
If Im understanding you. You have a pc then router then internet. Your applying it on the pc side of the router going out. If you do that it examines the packets when they head out of the router towards the pc. You want to apply the access-list on the in so it examines them as they go into the router.
Hope it helps,
Kyle
If your LAN facing interface is something like FastEthernet 0/1 then you want:
Interface FastEthernet 0/1
no shutdown
description connected to EthernetLAN
ip address x.x.x.x x.x.x.x
ip access-group 101 in
NOT
no shutdown
ip access-group 101 out
PS:
Doing the above would restrict access to other internal interfaces, if any.
thanks to everyone. I Have everything working the way I had planned.
