Block Intenret Traffic Using Extended Access List
cigalahgroup
Hello All,
 I have a fairly simple scenario where i am performing NAT to use internet on network and below is the configuration and I would like to Permit internet traffic on a single host and I have created an Extended access list but it doesn't works. Please check the statements below
ip access-list 102 permit 192.168.1.3 0.0.0.0 any eq 443
ip access-list 102 Permit 192.168.1.3 0.0.0.0 any eq 80
Then I applied this on my interface Ethernet0/0
ip access-Group 102 in
R1 CONFIG
Building configuration...
Current configuration : 2741 bytes
! Last configuration change at 14:38:57 UTC Sat Apr 5 2025
version 15.5
hostname R1
boot-start-marker
boot-end-marker
enable secret 5 $1$0McA$gZe2Qh4N69dVSFV/4LZ.b/
no aaa new-model
bsd-client server url https://cloudsso.cisco.com/as/token.oauth2
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no ip icmp rate-limit unreachable
no ip domain lookup
ip cef
no ipv6 cef
cts logging verbose
redundancy
no cdp log mismatch duplex
ip tcp synwait-time 5
 ip nat inside
 ip virtual-reassembly in
interface Ethernet0/1
 ip address dhcp
 ip nat outside
interface Ethernet0/2
 no ip address
 shutdown
interface Ethernet0/3
 no ip address
 shutdown
interface Ethernet1/0
 no ip address
 shutdown
interface Ethernet1/1
 no ip address
 shutdown
interface Ethernet1/2
 no ip address
 shutdown
interface Ethernet1/3
 no ip address
 shutdown
interface Ethernet2/0
 no ip address
 shutdown
interface Ethernet2/1
 no ip address
 shutdown
interface Ethernet2/2
 no ip address
 shutdown
interface Ethernet2/3
 no ip address
 shutdown
interface Ethernet3/0
 no ip address
 shutdown
interface Ethernet3/1
 no ip address
 shutdown
interface Ethernet3/2
 no ip address
 shutdown
interface Ethernet3/3
 no ip address
 shutdown
interface Serial4/0
 no ip address
 shutdown
 serial restart-delay 0
interface Serial4/1
 no ip address
 shutdown
interface Serial4/2
 no ip address
 shutdown
interface Serial4/3
 no ip address
 shutdown
interface Serial5/0
 no ip address
 shutdown
interface Serial5/1
 no ip address
 shutdown
interface Serial5/2
 no ip address
 shutdown
interface Serial5/3
 no ip address
 shutdown
router rip
 version 2
 redistribute static
 network 192.168.1.0
 no auto-summary
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 101 interface Ethernet0/1 overload
ip route 0.0.0.0 0.0.0.0 192.168.122.1
access-list 101 permit ip 192.168.0.0 0.0.255.255 any
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line vty 0 4
 access-class 10 in
 password cisco
 login
 transport input all
end
2 Accepted Solutions
M02@rt37
Hello @cigalahgroup
Allow DNS also on your ACL.
Best regards
Martin L
what exactly does not work?  2 notes: 1 , there is always deny any any statement at the end of every ACL - even if u do not see it; 2 , don't u need tcp keyword as in
access-list 102 permit tcp x y eq z
access-list 102 permit tcp 192.168.1.3 0.0.0.0 any eq 443
access-list 102 permit tcp 192.168.1.3 0.0.0.0 any eq 80
 Regards, ML
**Please Rate All Helpful Responses **
5 Replies 5
M02@rt37
Hello @cigalahgroup
Best regards
Martin L
 Regards, ML
I agree with M02@rt37 that the proposed ACL is too restrictive, needing DNS and probably some other protocols. It would be better if the ACL just permitted the host without worrying about specific protocols.
And I agree with @Martin L that the syntax of the ACL is incomplete.
And I would point out an issue with the configured default route:
 The configured next hop of 192.168.122.1 is an address that the router would not know how to get to. It is possible that since the interface uses DHCP to get its address, it might be that the router could learn a default route using dhcp, but the configured static default route needs to specify dhcp.
Rick
If you see the above configuration ip route is mentioned . My Question is
If there is any possibility to debug the access list and where where  the packets are getting dropped ?
Yes the configuration does mention routing. And I have pointed out that as configured it will not work as desired. You can solve this issue either by providing a correct next hop address, or by specifying that the default route is learned via dhcp.
If you want to debug the access list you could debug ip packet and the debug will tell you about all ip packets and what is happening to them. I am puzzled about asking "where the packets are getting dropped". They are dropped where the acl is applied.
Rick
