blocking eigrp update
rrmpejero
Im redistributing static routes to EIGRP.Is it possible to block the external EIGRP route update?so that other sites will not receive unneccesary routes.If possible,how can i do that?
pkhatri
Level 11
Level 11
You can block specific routes to neighbors using interface-specific distribute-lists.
For example, if you want to block route 10.0.0.0/24 (which is a redistributed static) from being sent over interface eth0, do the following:
access-list 10 permit 10.0.0.0 0.0.0.255
router eigrp 20
distribute-list 10 out Ethernet0
You can use this for both external and internal routes.
Hope that helps - pls rate the post if it does.
Paresh
Whoops... quick correction. The ACL should be:
access-list 10 deny 10.0.0.0 0.0.0.255
access-list 10 permit any any
Paresh
