01-12-2006 10:51 PM - edited 03-03-2019 11:26 AM
Current IOS Image Name: c1700-ipbase-mz.123-6f.bin
IOS Version: 12.3(6f)
Can anyone post a working sample cfg for Cisco 1721 to work with Sipura SPA-2000?
01-12-2006 11:32 PM
hi
Are you going to interface this box in the local lan switch and assign an IP Address , Gateway to the box ??
If thts the case then u can go ahead in doing normal config to ur router.
But do revert more about the ip scheme u have in place at present or u hve worked out for ur setup.
Also more details about your external connectivity to the outside world...
regds
01-13-2006 12:23 AM
in addition to Edwin´s post, you probably have to configure some sort of QoS for the voice calls. Judging from the Sipura SPA-2000 data sheet, it looks like SIP and RTP are being used by the box. A QoS could look like this:
class-map match-all VoIP_SIPURA
match access-group name VOICE
policy-map SET_VOIP_DSCP
class VoIP_SIPURA
set dscp cs5
interface FastEthernet0/0
service-policy input SET_VOIP_DSCP
ip access-list extended VOICE
permit tcp any any eq 5060
permit udp any any eq range 16384 32767
GP
