Blocking inbound access
mramj499
Have an ASR1001-X router as Internet router.  Got alert from Security team that ports 2001, 4001 and 9001 are open to the public on its public IP.  Trying to set up an access list on the gig port for the public IP that it blocks those TCP ports.  However, my access list isn't doing the trick, can still open ports 2001, 4001, etc.  Below config for the access list as well as the config for the port.  Any help is appreciated.  Thanks.
interface GigabitEthernet0/0/1
description Link to Firewall
ip address x.x.x.x 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip access-group 107 in
negotiation auto
cdp enable
end
ASR1001X-RTR#sh access-lists 107
Extended IP access list 107
10 deny ip any host 206.137.102.50 (1 match)
20 deny ip any host 206.137.102.100 (1 match)
30 deny ip any host 206.137.102.200 (1 match)
40 deny tcp any any eq 1433 (1 match)
50 deny tcp any any eq 3389
60 deny tcp any any eq 6001
70 deny tcp any any eq telnet
80 deny tcp any any eq 2001
90 deny tcp any any eq 4001
100 deny tcp any any eq 9001
110 permit ip any any (1183734 matches)
7 Replies 7
Joseph W. Doherty
Did the security team explicitly mention the open ports were only TCP ports?  I.e. what about UDP?
That aside, for an Internet facing interface, often you can start with blocking EVERTHING with the router's IP as the destination IP.  If something legitimate is blocked, add an ACE to allow just it.
Don't misunderstand the forgoing, I'm not suggesting blocking any transit traffic, just all traffic directed to the router's external interface IP.
mramj499
I've confirmed it's only TCP that is the problem right now.  Do you see anything wrong with my setup?  It's not actually blocking 2001, 4001, etc.
Are you sure that it is not blocking 2002 or 4001? Is there any proof that this traffic is actually getting into your network? The logic in the ACL looks right to me. The scanning program may say that this traffic is getting to the router interface, but the ACL should be quite effective in making sure that it does not get through into your network.
Rick
You've also confirmed the attempt to open those TCP ports is entering that port, i.e. not egressing that port?
I don't know what tool your infosec uses, but you can do simple telnet to router address with respective ports and see hit counts.
This works for TCP port verification.
HTH,
Hello
Appending a simple cbac should negate any external initiation of those tcp ports.
Example:
ip access-list extended firewall_acl
permit udp any any eq bootpc
deny ip any any
ip inspect name FW cbac tcp
ip inspect name FW cbac udp
ip inspect name FW cbac icmp
ip inspect cbac out
ip access-group firewall_acl in
Kind Regards
Paul
I send you message check it
