Blocking p2p connections on cisco 877w router
anthic.lobo
hi,
I want to block all sorts of peer to peer connections that would be initiated by users.
I could not find a configuration guide for 877w router.
What would be the steps required to block sites like torrent etc from being accessed by users
Giuseppe Larosa
Hello Anthic,
to verify if this can be feasible you should check if NBAR Network Based Application Recognition feature is available on your device.
read about NBAR
https://www.cisco.com/en/US/docs/ios/qos/configuration/guide/nbar_mqc_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1055125
you can use the feature navigator tool to check
www.cisco.com/go/fn
search by feature
type NBAR
choice
NBAR bittorrent PLDM
(NBAR uses special files separated from IOS for protocol definitions)
I see it for 881 or other 880 routers not for 877.
I see 877 listed for NBAR -pdlm versioning
So you may be able to configure qos policy-maps to drop or to limit peer-to-peer traffic as explained in first link above.
Hope to help
Giuseppe
