Blocking Peer to peer protocols on CAT 6500 Sup32PISA
ssanou.cfao
Dear,
I have install a CAT 6506e with Sup32PISA supervisor. I can see protocols with NBAR but I don't know have to apply blocking or limiting rules on peer to peer protcols. I also need to monitor graphicly the traffic on the CAT6500.
Thank you for your help
kyukim
Here is an example of using nbar to block P2P traffic.
class-map match-any p2p
 match protocol edonkey
 match protocol fasttrack
 match protocol gnutella
 match protocol kazaa2
 match protocol winmx
 match protocol skype
policy-map SDM-QoS-Policy-2
 class p2p
   drop
Interface vlan or X
service-policy input SDM-QoS-Policy-2
For graphical tool for 6500, you need to use either NetFlow collector tool or SNMP tool
to see traffic in graphic.
KK
Dear ;
Thank you for your support, i'll try it and be back to you very soon.
Dear,
I've try the configuration, but it doesn't work.
Please find attach the config file.
