Blocking Ports on Cisco Router
okoroji80
Dear Support Team,
kindly help with the guide on how to block the following ports on Cisco Router:
80 (HTTP)
20 (FTP)
21 (FTP)
530 (RPC
5 Replies 5
Hello
One crude method is to use a simple acl to acomplish this:
access-list 100 deny   tcp any any eq www
access-list 100 deny   tcp any any eq ftp
access-list 100 deny   tcp any any eq ftp-data
access-list 100 deny   tcp any any eq 530
access-list 100 deny   udp any any eq 530
access-list 100 permit ip any any
int xx
ip access-group 100 in
ip access-group 100 out
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
Thanks Paul.
however in applying the ACL to the interface, should it be In or Out ?
It all depends where are located the services that you want to block and if you have specified these ports as source or destination in your ACL. Don't forget that outbound ACL don't filter traffic generated by the router but that inbound ACL do so you should also be more specific  in your ACL but as Paul had not enough information he provided a "catch-all" ACL.
Alain
Hello Alain,
Besically the traffic is INBOUND. that is the restriction would be on the inbound traffic coming into the corporate network.
Then you can apply Paul's ACL inbound on your WAN interface if your services are on your corporate LAN.
Alain
