Booting issue
farkascsgy
Level 4
Level 4
I've a cisco 2611 router what shows the following output during the boot (and it's looped). I tried to enter to rommon, but I couldn't. Is there any procedure to recover the system?
System Bootstrap, Version 12.2(7r) [cmong 7r], RELEASE SOFTWARE (fc1)
Copyright (c) 2002 by cisco Systems, Inc.
C2600 platform with 98304 Kbytes of main memory
device does not contain a valid magic number
boot: cannot open "flash:"
an alternate boot helper program is not specified
(monitor variable "BOOTLDR" is not set)
and unable to determine first file in bootflash
loadprog: error - on file open
boot: cannot load "tftp:c2600-advsecurityk9-mz.124-13d.bin"
Thanks your help in advance
bye
FCS
Hello All,
I successfully resolved this booting issue, the procedure was the following:
I try to reseat the memory modules but it didn't solved the booting loop in next step I remove the interface card result was same finally I unmount the network modulo too ( so all modular things were remved). And during the boot the router caught the Ctrl+Break key sequence and went to rommon, whe the cards were installed it didn't recognize Ctrl+Break. After it IOS upload using tftp.
And now the router is up and running.
Bye
FCS
