Booting Problem in 7604 router...
ExceptionalBoy
When we tried to install the Ios image : c7600s72033-adventerprisek9-mz.152-4.S.bin,  we got the error below:
***System received a Software forced crash ***
signal= 0x17, code= 0x24, context= 0x441e395c
PC = 0x404b061c, Cause = 0x1020, Status Reg = 0x34008102
We verified the MD5 checksum of this image and it`s ok.
Could anyone give some insight on this?
Thanks in advance.
rsimoni
this is a crash; you need to open a TAC case attaching a show tech and crashinfo file for proper decoding.
If you cannot get them (because the sup keep on crashing) attach all the console outputs taken after you power cycle the box.
Riccardo
Thanks a lot Riccardo. For contacting TAC, waht`s best way?
Should we contact through CISCO reseller or TAC directly by ourself?
usually better to go direct. Thats assuming that the service contract is set up with you, and what the reseller is supposed to provide.
yes, go direct if you can
R
