Booting Stops Part Way, Is this a hardware issue?
minshullj
Long time reader first time poster.  I have a purchased secondhand 3550 and it has failed to finish booting.  Initially I tried switching console cables, and then computers.  Later I did upload a different, yet similar, IOS via xmodem and it stops booting at the same spot.  I assume it's a hardware issue but would like to see if it's possible I am wrong.  This is where it stops booting at all times:
7 Replies 7
Leo Laohoo
Could be a hardware failure or a corrupt IOS.
Post the boot up process.
Sent from Cisco Technical Support Nintendo App
If i am not wrong u re getting message password recovery mechanism is enabled.  Please trying chaning your config-register value to 0x2102.
Jawad
Keep in mind I switched out the IOS.  This is where is stops loading regardless of IOS:
File "flash:c3550-ipservicesk9-mz.122-25.SEC2/c3550-ipservicesk9-mz.122-25.SEC2.
bin" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C3550 Software (C3550-IPSERVICESK9-M), Version 12.2(25)SEC2,
RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Wed 31-Aug-05 10:18 by antonino
Image text-base: 0x00003000, data-base: 0x00D45320
Initializing flashfs...
flashfs[1]: 354 files, 5 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 15428096
flashfs[1]: Bytes available: 570880
flashfs[1]: flashfs fsck took 11 seconds.
flashfs[1]: Initialization complete.
...done Initializing flashfs.
POST: CPU Buffer Tests : Begin
POST: CPU Buffer Tests : End, Status Passed
POST: CPU Interface Tests : Begin
POST: CPU Interface Tests : End, Status Passed
POST: Switch Core Tests : Begin
POST: Switch Core Tests : End, Status Passed
POST: CPU Interface 2nd Stage Tests : Begin
POST: CPU Interface 2nd Stage Tests : End, Status Passed
POST: CAM Subsystem Tests : Begin
POST: CAM Subsystem Tests : End, Status Passed
POST: Ethernet Controller Tests : Begin
POST: Ethernet Controller Tests : End, Status Passed
POST: ILP Controller Tests : Begin
POST: ILP Controller Tests : End, Status Passed
POST: Loopback Tests : Begin
POST: Loopback Tests : End, Status Passed
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco WS-C3550-24-PWR (PowerPC) processor (revision D0) with 65526K/8192K bytes
of memory.
Processor board ID CAT0736Y00U
Last reset from warm-reset
Running Layer2/3 Switching Image
Ethernet-controller 1 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 2 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 3 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 4 has 1 Gigabit Ethernet/IEEE 802.3 interface
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
384K bytes of flash-simulated NVRAM.
Base ethernet MAC Address: 00:0D:BC:55:74:00
Motherboard assembly number: 73-8100-07
Power supply part number: 341-0029-02
Motherboard serial number: CAT07350URV
Power supply serial number: DTH07341SWG
Model revision number: D0
Motherboard revision number: A0
Model number: WS-C3550-24PWR-EMI
System serial number: CAT0736Y00U
Loopback is a traffic-affecting operationÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿü
I think this is a problem with your USB-to-serial connection.  Try another client.
Initially this is what I thought.  I then used my PC which has a serial port and tried two different cables.
I manage to solve this problem by deleting the config file.  For those who are unfamiliar:
Hold down the physical mode button on the front of the device while powering it on and release once the recovery menu has loaded.
Issue the flash_init command.
switch: flash_init
Delete the config file usually called config.text.  Eg: delete flash:/config.text
reboot
Jason
Thanks for posting back to the forum and letting us know that you have found a solution.
Knowing that you solved the problem by deleting the config makes it easy to look at the last message displayed in the boot process and wonder if some command in the config was enabling some kind of loopback.
Rick
Rick
