BOQ preparation
MAKhan
Would you be so kind to help me for below BOQ requirement, I need to connect 10 remote access sites to a central HO location with dual redundant link. Need your help to identify the correct router model with E1 module + switch information for Access as well as for HO.
Many thanks in advance for your kind help.
Remote sites:
20 Qty: Cisco 2911 router for remote sites.
20 Qty: Cisco Enhanced E1 module / High-Speed WAN Interface Card (HWIC-D) slots
20 Qty: Cisco 9300-24-T series switch
HO:
02 Qty: suggest the router model to connect 10 remote sites?
02 Qty: Cisco 9300 - 24-T series switch
12 Qty: Cisco Enhanced E1 module / High-Speed WAN Interface Card (HWIC-D) slots
option:
instead of HO routers can we use any L3 switch for E1 connectivity instead of using Router with E1 module?
Georg Pauwen
it all depends on your budget, but you could use the NIM-1MFT-T1/E1 1-port multi-flex trunk voice/clear-channel data T1/E1 module in conjunction with the 4451-X Integrated Services Router...
https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/qa_c67-728823.html?dtid=osscdc000283
