Box-to-Box NAT/HSRP configuration Cisco ISR 4431 version 16.09.05
jamesupcott1
Hi All
I have a Cisco ISR in live production, and we have just purchased an additional to run HA for redundancy. I have configured HSRP successfully on the two ISR routers. I have a few SNAT configurations, which I need to ensure work successfully in the event of a failover. I have read the following link (https://content.cisco.com/chapter.sjs?uri=/searchable/chapter/content/en/us/td/docs/ios-xml/ios/ipaddr_nat/configuration/15-mt/nat-15-mt-book/iadnat-b2b-ha.html.xml), which seems to be what I need, however I would like some additional advice on what my exact configuration will need to look like. I have pasted the configuration of my primary ISR below (I have amended the public IP FYI before anyone mentions). We want them to run active/passive (No asymmetric routing or LB)
interface GigabitEthernet0/0/1
description Inside_WVT-RA-VPN
ip vrf forwarding S2S_VPN
ip address 10.14.64.253 255.255.255.0
ip nat outside
standby 1 ip 10.14.64.1
standby 1 preempt
negotiation auto
no ip virtual-reassembly
no ip virtual-reassembly-out
interface GigabitEthernet0/0/2
description ***Internet_Out_cpe-hfc-hch-a***
ip address 25.255.48.235 255.255.255.240
ip nat inside
ip access-group BLOCK_UDP_EXTERNAL in
standby 2 ip 25.255.48.237
standby 2 preempt
standby 2 name HSRP2
negotiation auto
interface GigabitEthernet0/0/3
description Inside_WVT-S2S-VPN
ip address 10.14.65.253 255.255.255.0
ip nat outside
standby 3 ip 10.14.65.1
standby 3 preempt
standby 3 name HSRP3
negotiation auto
ip nat pool Inside_WVT_S2S_VIP 10.14.65.1 10.14.65.1 netmask 255.255.255.0
ip nat pool Inside_WVT_RA_VIP 10.14.64.1 10.14.64.1 netmask 255.255.255.0
ip nat inside source list 155 pool Inside_WVT_RA_VIP vrf S2S_VPN overload
ip nat inside source list 160 pool Inside_WVT_S2S_VIP vrf S2S_VPN overload
ip nat inside source list 170 pool Inside_WVT_S2S_VIP vrf S2S_VPN overload
ip nat inside source list 180 pool Inside_WVT_S2S_VIP vrf S2S_VPN overload
ip nat inside source list 190 pool Inside_WVT_S2S_VIP vrf S2S_VPN overload
ip nat inside source list 195 pool Inside_WVT_S2S_VIP vrf S2S_VPN overload
ip nat outside source static 10.14.64.2 25.255.48.229 vrf S2S_VPN add-route
ip nat outside source static 10.14.65.2 25.255.48.238 vrf S2S_VPN add-route
ip nat outside source static 10.14.65.4 25.255.48.233 vrf S2S_VPN add-route
ip nat outside source static 10.14.65.5 25.255.48.234 vrf S2S_VPN add-route
ip nat outside source static 10.14.65.6 25.255.48.232 vrf S2S_VPN add-route
ip nat outside source static 10.14.65.7 25.255.48.230 vrf S2S_VPN add-route
ip route vrf Mgmt-intf 0.0.0.0 0.0.0.0 192.168.99.1
ip route vrf S2S_VPN 0.0.0.0 0.0.0.0 25.255.48.225
ip access-list extended 155
permit ip any host 25.255.48.229
ip access-list extended 160
permit ip any host 25.255.48.238
ip access-list extended 170
permit ip any host 25.255.48.233
ip access-list extended 180
permit ip any host 25.255.48.234
ip access-list extended 190
permit ip any host 25.255.48.232
ip access-list extended 195
permit ip any host 25.255.48.230
Any help would be really appreciated.
8 Replies 8
check my below comment
Thanks. I am looking though for how the configuration I posted before would look like of it were to be adapted?
check below comment
No, my ISR doesn’t accept that configuration.
It looks to accept the syntax I mention in my original post, I’m just unsure of how that will exactly look on my existing configuration, as the NAT config is very much standalone currently.
friend there is different between IOS-XE HA and HSRP, your config is pure HSRP, I will run lab for IOS-XE and see how we can make NAT ware of HSRP.
Can you provide an example, using my configuration below, on how the configuration should look?
ip nat outside
standby 1 preempt
negotiation auto
ip nat inside
standby 2 preempt
negotiation auto
ip nat outside
standby 3 preempt
negotiation auto
Awesome thankyou very much. I look forward to hearing from you.
